0 registered (), 127 Guests and 0 Spiders online.
#181216 - 26/06/01 09:12 PM Jacks
Bill H Offline
Loc: Northern NJ USA
Today I did some experimentation where I was "trying on" some new tires and rims. I got out my 2-1/2 ton rolling floor jack and slid it under the front end of my X where the designated lift points are and started pumping. Only problem is the jack was totally vertical and did not lift the vehicle off the ground. It did not raise high enough so I was forced to take out the factory supplied jack and it worked fine. A little more exercise for me in 90 degree weather but it worked. I didn't want to risk safety and use blocks on the floor jack. Just wanted to point this out to those of you looking to buy a floor jack. I do have a hi lift jack on the way but its not here yet.
2001 Xterra 4x4 SE Yellow
#181217 - 27/06/01 01:22 AM Re: Jacks
With a floor jack, just put it under the lower control arm.
Regards,
Ian
#181218 - 27/06/01 06:22 AM Re: Jacks
Though be careful it doesn't slip, I don't think there's a truly horizontal surface to put it under...
#181219 - 27/06/01 03:12 PM Re: Jacks
superjens Offline
Loc: North Vancouver
Where would you use the high-lift? I thought there was some discussions about it being kind of useless on the Xterra, unless you had an ARB bumper up front (or similar), and a hitch in the back. If there is a reasonable way to use it, off to the store I go to buy one.
For a good time call 800-565-3673
#181220 - 27/06/01 05:20 PM Re: Jacks
silverxglider Offline
Loc: Andes, NY
I got a floor jack with (I think) 21" of lift. Had no problem rotating the stock tires last weekend with the jack under the frame in the front. I had to shop around a bit to find one with that much lift though.
[This message has been edited by silverxglider (edited 06-27-2001).]
Boldly going nowhere.
#181221 - 27/06/01 09:20 PM Re: Jacks
Bill H Offline
The floor jack, although it lifts way more than I need it to, does not have adequate lifting height.
#181222 - 28/06/01 10:59 AM Re: Jacks
number41 Offline
Loc: Tucson, AZ
I found a floor jack at Sears for 99 bucks on sale with jackstands. It lifts 19.25" inches and is plenty to get the wheels off the ground using the jack points or the frame.
All your trail are belong to us
-Xavier
Moderator:  johngraves2
