#185837 - 25/07/01 06:59 AM How to remove the sunroof
O'Polka Offline
Loc: Arlington,TX USA
There has been some discussion on the removal of the sunroof latley. I have taken some pics to guide you through it. It is simple and takes less than a minute to do so.
The first pic shows the sunroof latch in the down position with my device to push the pin in place.
[img]http://albums.photopoint.com/j/View?u=1435837&a=13534750&p=52066815[/img]
the next pic shows what pin I am pushing. this must be repeated for the opposite side. apply a little outward pressure to the first side you did so it does not go back in. when the second pin is pushed in the latch should pop out.
[img]http://albums.photopoint.com/j/View?u=1435837&a=13534750&p=52067440[/img]
[img]http://albums.photopoint.com/j/View?u=1435837&a=13534750&p=52066818[/img]
the last pic shows the sunroof in a verticle position. When in this position just pull toward the drivers side.
[img]http://albums.photopoint.com/j/View?u=1435837&a=13534750&p=52067445[/img]
Reinstallation is easy but a little tricky. You must push down and push right while putting the roof back on to its hinges. It take a couple time to get the feel. good luck.
John O'Polka
2001 SE 4x4
Goldrush smile
John O'Polka
His and Hers Mustang GT's Extreamly modified! Big cams and NOS
#185838 - 25/07/01 11:02 AM Re: How to remove the sunroof
BennyLen Offline
Loc: Huntsville, AL
I thought, at least on the 2000 models, it was impossible to get the sunroof out without removing the rack. Once it was vertical the rack would interefer too much to slide it sideways. Are the 2001 models in a different position to allow for it to slide now?
Benny, 2000 SE, 4x4, auto Solar Yellow
Benny's Xterra site
Benny
Benny\'s Xterra site
#185839 - 25/07/01 11:39 AM Re: How to remove the sunroof
O'Polka Offline
2000 is the same as 2001. the rubber trim around the sunroof does rub, but it does squeeze thru. It takes a little pressure but not much to get it verticle.
John O'Polka
2001 SE 4x4
Goldrush smile
John O'Polka
#185840 - 08/08/01 04:56 AM Re: How to remove the sunroof
TKNice Offline
Loc: Cooksville, MD '01 Gold Rush S...
Any problems with leaking?
-Tom
#185841 - 08/08/01 06:58 AM Re: How to remove the sunroof
Snoopy Offline
Loc: San Diego CA
None here. I've ran a garden hose over the top without any problems.
Snoopy , our '00 Cloud White SE, 4x4, 5SP
#185842 - 08/08/01 08:05 PM Re: How to remove the sunroof
Matt Peckham Offline
Loc: Charlotte, NC
with the sunroof off? Wow. that's amazing.
Prisoner #1403952
and what did you do today?
The Van LIVES.
#185843 - 30/09/01 05:02 PM Re: How to remove the sunroof
yxterra Offline
Loc: Huntington, WV
Where have all the pictures gone? confused
So much to do, so little money.
#185844 - 30/09/01 07:54 PM Re: How to remove the sunroof
xcanuk Offline
Loc: Mtl. Que. Canada
There were linked to photopoint, when it was free to do so.
member of http://www.soxc.org
Moderator:  johngraves2
