#188898 - 17/10/02 02:58 PM TCC SOLENOID VALVE ...
mygreenX Offline
Loc: Long Island, NY
CAN SOME ONE TELL ME WHERE THE TCC SOLENOID VALVE IS? ...MY S.E.S LIGHT CAME ON(00'X)-I GOT THE DIAGNOSTIC TEST DONE AND MY TCC SOLENOID VALVE NEEDS REPLACING.... IF ANYONE CAN HELP I'D REALLY APRECIATE IT...THAN"X" [Freak]
Night Armor S 4x4 2006
Molten Silver SpecV 2004 SOLD
Alpine Green SE 4x4 2000 SOLD
#188899 - 17/10/02 04:35 PM Re: TCC SOLENOID VALVE ...
See that key on your keyboard labeled "CAPS LOCK" ?
Turn it off.
#188900 - 18/10/02 08:31 AM Re: TCC SOLENOID VALVE ...
It's your torque converter control solenoid, and it's on the valve body inside your transmission. Not a quick and easy replacement for a DIY type.
#188901 - 19/10/02 10:09 PM Re: TCC SOLENOID VALVE ...
Nut Offline
Loc: Calif
I wouldn't be to quick to replace that solinoid without verifing it's bad. The TCC fault code is for the Torque Converter Clutch circuit and is not a hard code, it's Assumed by the ECU. Road test to verify if the converter is locking up after going into overdrive, feels like the tranny shifts again but only drops a couple of hundred RPM. If not then check the resistance of the circuit/solinoid. If it does seem to lock up but still sets the code you got a bigger problem then the solinoid, ie. pull the tranny/transfere case to check the o-rings at the front pump and input shaft from the converter. Could be tranny time.
[Crybaby]
Sometimes you feel like a Nut,
sometimes you don't.
Moderator:  johngraves2
