#190949 - 11/07/04 08:22 PM Anyone have a Craftsman Floor Jack?
NetJunkie Offline
Loc: Raleigh, NC
I have one that's about 4 months old and is losing power. About 3/4 of the way up it won't even lift a can of paint. Is there anywhere to add hydraulic oil to it? Anything ot check? No clue where my receipt is so I doubt I can swap it (no lifetime on the jacks).
It's the Craftsman Professional 3 1/2 Ton seen here:
http://www.sears.com/sr/javasr/product.d...0&bidsite=CRAFT
#190950 - 11/07/04 08:28 PM Re: Anyone have a Craftsman Floor Jack?
DesertHB Offline
Loc: Huntington Beach, CA
I had the same one with the same problem. I tried bleading air out of it and topping off the oil. Ended up returning the POS and getting my money back.
I ended up getting one from PepBoys. It was less money and works great.
Doug
#190951 - 11/07/04 08:31 PM Re: Anyone have a Craftsman Floor Jack?
NetJunkie Offline
Loc: Raleigh, NC
How do you top off the oil? No receipt so no return so I might as well use it as a secondary jack. I'm going to buy anohter (not the same one) as I need two.
#190952 - 12/07/04 04:29 AM Re: Anyone have a Craftsman Floor Jack?
cygnus67 Offline
Loc: Southern NJ
I've got the same jack. Sounds like you've got air trapped in the system. I believe the "bleeding" instructions go something like this: jack the lifting arm all the way up. Loosen, but do not remove the fill / bleeder bolt (keep it finger-tight). Lower the lifting arm. Slightly loosen the fill / bleeder bolt when the lifting arm is all the way down. You should hear air escaping if there is any. Tighten bolt. Repeat as necessary.
Eagles may soar...but weasels don't get sucked into jet engines!
#190953 - 12/07/04 06:34 AM Re: Anyone have a Craftsman Floor Jack?
NetJunkie Offline
Loc: Raleigh, NC
Not to be an idiot....but can you tell me which screw that is?
#190954 - 12/07/04 07:30 AM Re: Anyone have a Craftsman Floor Jack?
cygnus67 Offline
Loc: Southern NJ
It's just below where you put the handle into the jack. Might still have a little plastic cap on it? Mine even has "hydraulic jack fluid only" stamped by the bolt but don't count on seeing that. My neighbor has the exact same one sans stamp. FWIW - if you get it working correctly again, be a bit more aware of how you transport / store it. I caused my own problem by setting it sideways while moving some stuff in my garage.
#190955 - 12/07/04 03:55 PM Re: Anyone have a Craftsman Floor Jack?
Its a Craftsman, take it back to sears, they will replace it for free.
#190956 - 12/07/04 03:59 PM Re: Anyone have a Craftsman Floor Jack?
NetJunkie Offline
Loc: Raleigh, NC
The warranty isn't the same on floor jacks..only the tools.
#190957 - 13/07/04 09:13 AM Re: Anyone have a Craftsman Floor Jack?
Heath22 Offline
Loc: Dacula, GA
[b]Its a Craftsman, take it back to sears, they will replace it for free.
The warranty isn't the same on floor jacks..only the tools.[/b]
It still has a one year warranty and it's a Craftsman so there is no doubt where you bought it. Trust me, they stand behind all their products, not just their tools. Try it and see. Make a fuss if you have to. And don't they get your phone number and stuff when you buy from Sears? I can't remember, but I think they have every time I've bought a tool or something from them. So they might have you in their system. Plus, there might be a manufactor date stamped or on some kind of tag to prove age. I would still try is all I'm saying.
WilMac you're a dumbass!!
#190958 - 13/07/04 10:29 AM Re: Anyone have a Craftsman Floor Jack?
If you bought it with a credit card then use your credit card statement as proof of purchase. Sears wont give you a hard time returning it.
Moderator:  johngraves2
