#191746 - 23/03/02 01:23 PM oil change intervals
buck Offline
Loc: Shohola,PA. 18458
Have a 2002 XE V-6 Xterra. Have had it only 2 wks.In checking the maintenance manual/schedule, it refers to first oil change @ 3750 miles/3 mos.Should I do the first oil change then or at 1000 miles. Thanks for your input.
#191747 - 23/03/02 03:28 PM Re: oil change intervals
PismoTaco Offline
Loc: Bakersfield, CA
I agree,, I'd do my 1st few oil changes early.
-Chirs
This is the place brillant minds assemble to carefully pool ignorance with questionable logic in order to reach unworkable solutions.
#191748 - 24/03/02 11:49 AM Re: oil change intervals
DaveDatsun Offline
Loc: Sahuarita, AZ
I also agree. You can't go wrong with an early oil change.
dave and xtoy - off to a good start
#191749 - 24/03/02 02:02 PM Re: oil change intervals
krisjon Offline
I'd give it a 1000 miles or so and drop the oil out of it. That will help get rid of some of the initial break-in. After that, do it again around 3,000-3,750 or so.
I did that, then switched to Mobil 1 synthetic after roughly 10k...running smooth and purring like a kitten ever since.
#191750 - 26/03/02 05:34 PM Re: oil change intervals
buck Offline
Thanks for your input; however, is synthetic oil that much better? I would change oil and filter every 3000 miles. With synthetic oil what would the change intervals be? Thanks for your help..
#191751 - 26/03/02 07:07 PM Re: oil change intervals
PismoTaco Offline
I wouldn't switch over to synthetic until 10,000 miles,, +/- 5,000 miles.
As for synthetic, yes it is a lot better.. You're really gonna get a slew of answers on this, but i run amsoil 0-30W for 25,000 miles/ 1 year and change my oil filter every 6 months. I have done oil analysis and oil is fine.
-Chris
#191752 - 30/03/02 09:47 AM Re: oil change intervals
SquidlyX Offline
Loc: Chula Vista,CA
I've had my X for 7 months now.Had the dealer change it the first time at 3200 only because we went on a 2500 mile road trip to break her in.Changed the oil again at 7500 but this time I did it myself and used Mobil1 5w-30 and a Mobil1 filter.5000 miles later changed again only this time used 0w-30 instead.With the 0w-30 the oil flows faster at start-up and don't get the annoying lifter noise.Also the engine seems livelier off the line.If Roger Penske uses the stuff it's good enough for me.
Volant, Gibson, That Dam Mod
"Eating and sleeping are the only activities that should interrupt a man's enjoyment of his cigar" Mark Twain.
#191753 - 31/03/02 03:37 PM Re: oil change intervals
DaveDatsun Offline
Loc: Sahuarita, AZ
As moderator of this forum I want readers to realize that using lubricants that do not match the manufacturer's specs can compromise your warranty.
If you are beyond warranty or don't care or know more than the manufacturer, than do whatever you want.
dave and xtoy - it's your ride
#191754 - 01/04/02 04:36 AM Re: oil change intervals
If you use a proper filter with a good anti-drainback valve, you shouldn't get much if any lifter noise at startup and therefore won't feel compelled to use thinner oil (0W30) to get rid of this so-called "problem" which is harmless.
Moderator:  johngraves2
