You will have to recharge the system. But there's more...
Once you open the system (the stick already did) you have to evacuate the system with a vacuum pump before you charge it. Then you have to charge it with the right amount of compressor oil and refrigerant.
Most of us don't have access to the vacuum pump you'll need. If you skip that step, moisture trapped in the system will cause it to freeze up inside.
