Hi CharlieX,
I changed the air filter at 20,000 miles, now the X is 27,000. I'll still check to see if the filter is clogged. BTW, is there any relation between air filter and fast engine rev?
Paul,
I checked the pedal cable and there is enough play for the throttle plate to return to idle stop. I manually roll the throttle pulley and it also return fine. But whatever way I tried, the engine just hesitate or slowly returning back to a higher idling speed...
Thanks for you info about where the adjusting screw is. I still couldn't find it, will have to try again in the next few days when the weather is warmer...
Thanks,
xxxsolarxxx
