#245110 - 24/09/04 01:10 PM Almost done!!!
Here's where we are now.
Thought some of you might like to see them. laugh
#245111 - 24/09/04 01:43 PM Re: Almost done!!!
superjens Offline
Loc: North Vancouver
Got anything bigger?
#245112 - 24/09/04 01:54 PM Re: Almost done!!!
#245113 - 24/09/04 02:27 PM Re: Almost done!!!
Fixed it I hope.
#245114 - 24/09/04 02:31 PM Re: Almost done!!!
socalpunx Offline
Editor, that looks great. Those CO's are monsters.
What is the expected suspension travel? This is with a 4wd I assume?
Along with the tie rods are they going to produce a new CL/Idler/Pitmal Arm?
#245115 - 24/09/04 02:40 PM Re: Almost done!!!
We are doing final measurements today. It's somewhere between 12 and 14 inches of travel. I don't know about the droop yet. There will be no tie rods per say. Heim joints will be replacing them. I don't have the answers for the other stuff yet. I can say yes, I just don't know when.
Oh yeah I forgot. It is 4wd.
#245116 - 24/09/04 02:47 PM Re: Almost done!!!
Looks sweet!!! [ThumbsUp]
#245117 - 24/09/04 03:23 PM Re: Almost done!!!
socalpunx Offline
Do they still require a 17inch wheel to clear the spindle or no?
I heard that Hanniman is going to rework the front X fenders for you guys? You didn't like the original ones or the fit wasn't right or it's all just a nasty rumor?
#245118 - 24/09/04 03:29 PM Re: Almost done!!!
No...there is no spindle now so you can run any wheel you want. I put on 15's with 33" BFG's. Yeah, the front is being totally reworked. The originals were based off a '99 Frontier so the fit was not quite right. AC had the same problem. Hannemann is reworking both the front fenders and the valance/bumper cover. It will be sweet when it's all done and painted.
#245119 - 24/09/04 03:31 PM Re: Almost done!!!
If the above is true, let me know if you still need a trim on that bumper...Steve is in MA right now, but he'll be back in the beginning of October.
Good luck, looks great so far.
#245120 - 24/09/04 04:14 PM Re: Almost done!!!
socalpunx Offline
[b]Do they still require a 17inch wheel to clear the spindle or no?
No...there is no spindle now so you can run any wheel you want. I put on 15's with 33" BFG's. Yeah, the front is being totally reworked. The originals were based off a '99 Frontier so the fit was not quite right. AC had the same problem. Hannemann is reworking both the front fenders and the valance/bumper cover. It will be sweet when it's all done and painted.[/b]
So basically that's why mine were a bitch to fit. What are they doing with the bumper/cover? Will it be a stand alone piece or will be be part of the fender/hood set up?
#245121 - 24/09/04 05:25 PM Re: Almost done!!!
xterrabull Offline
Loc: san jose, CA, USA
That looks nice!
It's probably just a trick of the picture, but it kind of looks like the lower coilover mount would be close to binding at full stuff...but I'm sure it's been tested for....
Nice work! [ThumbsUp]
#245122 - 24/09/04 06:57 PM Re: Almost done!!!
I have not talked to them in a week or so, but it's in 3 separate pieces. The front could probably be sold as a stand alone. The cover will basically follow the lines of the fender well to a natual termination point. It looks a lot like the Total Chaos Frontier that was at Expo last year.
#245123 - 24/09/04 06:59 PM Re: Almost done!!!
Huey Offline
Loc: Hayward, CA
So are you using the stock CV joints or is there a solution for that?
-Huey
#245124 - 24/09/04 07:06 PM Re: Almost done!!!
No one is making aftermarket CV's for a Nissan that actually work. The longer axles relieve some of the stress that full droop would otherwise cause. There are also talks about a differential drop kit in the future to relieve the angle another few degrees.
#245125 - 27/09/04 08:57 AM Re: Almost done!!!
[b]So are you using the stock CV joints or is there a solution for that?
No one is making aftermarket CV's for a Nissan that actually work. The longer axles relieve some of the stress that full droop would otherwise cause. There are also talks about a differential drop kit in the future to relieve the angle another few degrees.[/b]
I thought Nicole was telling me they replaced the axles?
#245126 - 27/09/04 10:20 AM Re: Almost done!!!
Yes there are new axles there. Look a few posts up.
