#26102 - 23/11/07 10:26 AM CB antennas
Hi well we picked up a CB today and now we are wondering what antenna we should use and where we should place it. So if you guys could give some pics of where you guys put your antennas. Thanks, Dylan.
#26103 - 23/11/07 10:30 AM Re: CB antennas
Dylan..I just mounted mine and I was curious about the antenna too. Do a search in the communications forum and ALL of your questions will be answered.. [Wave]
#26104 - 23/11/07 12:03 PM Re: CB antennas
Ditto
one thread that may help
#26105 - 24/11/07 08:15 AM Re: CB antennas
Canope Offline
Loc: Pennsylvania
I grabbed a Lil' Wil.
Magnetic mount up top right behind the basket. Coax right down inside the rear door and under the seat. Quick and painless plus a quality antenna.
Thomas
"A great civilization is not conquered from without until it has destroyed itself from within."
#26106 - 25/11/07 09:28 PM Re: CB antennas
I've got a Wilson 5000 (with 5 foot whip) mounted on the center of the roof.
#26107 - 27/11/07 01:25 PM Re: CB antennas
Canope Offline
Loc: Pennsylvania
Gotta add...Don't buy one from just any store and stick it up there. It will need to be tuned first for best results. You can spend good cash and still suck.
Thomas
#26108 - 27/11/07 08:51 PM Re: CB antennas
Agreed. I had my CB and antenna installed by a professional CB shop - not some fly by night operation. Making sure your setup is tuned does make a huge difference both in reception and in transmission.
#26109 - 28/11/07 04:59 PM Re: CB antennas
Go with a mounted antenna, not the magnet type. Low branches will take out magnet antennas. I have a firestik mounted to my rear tire carrier and has faired well with trees on the trail. Magnet type are also easier to steal, has happened to me before. I agree with AZ-Ted, a professional install is the best way to go to get the best out of the antenna's range, dependent upon placement of the antenna.
Linky
#26110 - 29/11/07 07:47 AM Re: CB antennas
Ditto on the search in the Communication forum, I've posted numerous tips and tricks and had long discussions on how to get the most out of a CB.
You could mount one of these, they make a great antenna:
http://tarheelantennas.com/model_100a_hp
(It's a bit overkill for CB, being that you'll never move it again after tuning it)
#26111 - 30/11/07 01:30 PM Re: CB antennas
Canope Offline
Loc: Pennsylvania
Would a ham antenna work on a cb?
Thomas
#26112 - 02/12/07 09:02 AM Re: CB antennas
That particular antenna will tune to the CB bands, but you'll loose more than you gain due to ground effect. Matching coils are rough on a single band radio at 4 watts....
I recommend this antenna for CB use:
http://hamstick.com/9010.htm
CB is 11 meter wink
Mike is a good guy, makes excellent antennae.
