Originally posted by Rick Abt:
Seems everyone here is hot for the BFG's....I am considering Yokohama Geolandars in 265-75-16 size...they are much less expensive and I have heard that they are better in wet weather and packed snow....They do not have the rim protector though, and I am not sure which tire would be best off road....Have heard the BFG's wear better....Was also considering the Revos, but heard that they are not as capable off road, yet are flawless in wet weather...any opinions or insights??
I'm sure you can do a search and get more details, but in general here are my opinions about the tires:
Yokos - cheap, good snow and wet traction, they wear down pretty fast because of the soft compound.
Revos - tied with the BFG as the best AT tire you can get, these have the edge over the BFG's on the road - little bit less noise, little better wet and snow traction. You can get lighter rated versions for less than the BFG's, but the cost is basically the same if you get the D rated tires.
BFGs - compared to the Revos the BFG's aren't quite as good on road, but they have the edge in off-road performance, they are tougher (three ply sidewall, rim protector), and they wear like iron. They look more aggressive then the Revos, if that's important to you.
I went with the BFG's, but the Revos are an awesome choice too. Go to tirerack and you can look at a bunch of reviews for these tires.
