#265751 - 26/01/08 11:14 PM Rear Brake Hard Line Replacement... Part Source?
ivorykid Offline
Loc: Orange County
On my 2002 Xterra, the over sized spare (265/75R16 BFG T/A KO) managed to eventually crush / wear a hole in the brake hard line that follows the rear axle from the t-block that distributes the hydraulic fluid to left and right brakes (sorry, I don't know all the wrench lingo yet) to the drum housing.
I figure that the replacement is easy enough, but where do I find the hard line and fittings? My local Kragen has straight hardline, but I need it formed like the OEM part. Is the forming something that I need to do on my own?
If anyone has a part number or source for the part that I am looking for, I would be very appreciative! I would prefer to pick it up locally so I can get my truck back operational again ASAP if possible. I'm in SoCal, specifically the OC.
Thanks!
Erik
Why is it called a "building" if it is already "built?"
#265752 - 27/01/08 08:51 AM Re: Rear Brake Hard Line Replacement... Part Source?
Stonecoldchavez Offline
Loc: New Jersey
Well, you can probably get it pre-bent from the dealership. Have you tried xterraparts.com?
Or you can get the straight line and a manual pipe bender and bend it up yourself.
Or you try this place I found in the back of Fourwheeler magazine, www.inlinetube.com. See if they have anything.
S.
