#266253 - 04/02/02 06:10 AM Rub-a-dub-dub? 31x10.5 on AR 15x8 767
mudflap Offline
Loc: Rockville, Maryland
This AR black steel wheel has the closest to stock backspacing, 4.75 vs 5.00 stock. Will it work on a stock lift X?
'02XE4x4EnthusiastPkg
#266254 - 04/02/02 07:01 AM Re: Rub-a-dub-dub? 31x10.5 on AR 15x8 767
KCX Offline
Loc: Kansas
Stock lift X? If your meaning the rear shackle lift with the torsion bar adjustment then I'm sure with only a .25 difference, you'll be fine. I have the same "lift" with the BFG 31x10.5x15 A/t KO's and stock wheels, but I had only little trimming and they work great. Even SOME club memebers with 32" don't rub, so I bet you will be just fine. Many people I have heard/seen has the same setup that your asking about and I haven't heard of them having any problems. laugh
[ 02-04-2002: Message edited by: XTERRA4EVER ]
www.hxoc.net
#266255 - 04/02/02 07:13 AM Re: Rub-a-dub-dub? 31x10.5 on AR 15x8 767
xcanuk Offline
Loc: Mtl. Que. Canada
Correct me if I'm wrong, but you're comparing apples and oranges. Backspacing is different according to rim width. 4.75 b.s. on a 8" rim does not equal 4.75 on a 7" rim ( there is more than a .25 difference in your case ) I drew this up a while ago, with the numbers I had at the time, but it gives you a visual (copy&paste) http://www.geocities.com/x_canuk/rim.JPG
member of http://www.soxc.org
#266256 - 04/02/02 10:17 AM Re: Rub-a-dub-dub? 31x10.5 on AR 15x8 767
mudflap Offline
Damn interesting, xcanuk. Will peruse it at length later. Currently in harness at work. frown
