#267206 - 22/03/01 04:57 PM Widest Tire on stock 15x7 wheel
yellow-Xdude Offline
Loc: Bradenton, Fl
I'm considering upgrading my tires in the future and want to go wider vs. taller. I know the BFG AT KO's come in a 325/60R15 which is 12.9" wide and 30.5 in diameter. Is it possible to put these on a 15x7 or do I need to go with a new wheel, 15x9? I'm wanting to keep the stock wheels if possible, I just don't want to be unsafe. Most people are putting 31x10.5R15 on and I'm looking for an AT that is 30 or 31x11.5 or wider. Has anyone had any experience with wider tires on the stock wheels?
#267207 - 22/03/01 07:05 PM Re: Widest Tire on stock 15x7 wheel
gothamist Offline
Loc: Virginia
Well, the problem is...unless I'm entirely off my rocker and my X is an abberation...those tires won't fit in the rear wheelwells, the wheelwells are too narrow. I also believe those tires are too wide to fit on a 7" rim, I know of people running 12.5" wide tires but that's pretty much the limit on a 7" (and they have to be friends w/ the tire shop that does the mounting...)
http://www.4x4LO.com
#267208 - 23/03/01 06:20 AM Re: Widest Tire on stock 15x7 wheel
Tex-X Offline
Loc: Crystal Lake, IL USA
Where are you measuring width of the tire? The tread width varies too much and has no bearing on rim size. Width should be measured side wall to side wall at the widest point. To answer your question, as you go wider you need wider rims. Here is some base information using the Bridgestone AT as the standard.
30x9.5R15 - 9.9" wide - 6.5 to 8.5 rim approved
31x10.5R15 - 10.9" wide - 7.0 to 9.0 rim approved
32x11.5R15 - 11.9" wide - 8.0 to 10.0 rim approved
33x12.5R15 - 13.0" wide - 8.5 to 11.0 rim approved
Hope this helps.
"You are talking about the non-sensical ravings of a lunatic mind."
-Frederick Von Frankenstein-
#267209 - 23/03/01 09:04 AM Re: Widest Tire on stock 15x7 wheel
That's 11.50 width. Any wider and you'll likely have contact about where the arrow points.
#267210 - 23/03/01 09:47 AM Re: Widest Tire on stock 15x7 wheel
Chris Mc Offline
Loc: St Charles, MO
I was wondering the same thing. I went off of BFG's stats, with the widest tire I could put on the stock 15x7 wheels being a 31x10.50x15. I have seen a lot of 32x11.50's on what appear to be stock wheels, though. What size wheels are folks using for their 32x11.50's? If they fit on the stock 15x7's, anyone wanna buy some 31x10.50's? (low miles!)
Chris McCracken
"He who dies with the most toys ...WINS!"
Join the Heartland Xterra Owners Club www.hxoc.net
#267211 - 23/03/01 10:35 AM Re: Widest Tire on stock 15x7 wheel
gothamist Offline
Loc: Virginia
People are using the stock rims--I don't think anyone has 32's on non-stock, actually, as at that size you need the stock offset and backspacing to make them fit (unless you're running a lift.)
I have my Swampers on stock rims...32x11.50. The tire shop had a bit of a struggle to mount them up (they are held onto the rim with a lot of pressure), but otherwise no problems.
#267212 - 27/03/01 12:34 PM Re: Widest Tire on stock 15x7 wheel
Rebel Offline
Loc: Gate City, Virginia USA
i have my 32" swampers on non stock wheels. i ordered some black steel rims from stockton wheel in california and they custom make the wheel to the exact backside setting and offset of the stock x wheels. that way you don't encounter any of the problems of using wheels that differ from the stock specs.
Ed Britt
black '00 XE 3 pack 4x4
ARB
32" Super Swamper TSLs
#267213 - 27/03/01 01:03 PM Re: Widest Tire on stock 15x7 wheel
Hunter Offline
Loc: Lyndhurst, NJ
Caver-X, how much for the 31x10.5x15's (How much is low mileage)
Alpine Green
Auto 4x4 00 Xterra XE
520 PIAA Fog Lights
#267214 - 27/03/01 01:43 PM Re: Widest Tire on stock 15x7 wheel
Chris Mc Offline
Loc: St Charles, MO
I have about 1200 miles on them now. All pavement and gravel so far (unfortunately), no curbs or anything nasty. Not really sure how much to ask for them.... they're about 115 new... Mainly I'd just need a good chuck o' cash towards 32's. I'd imageine the hard part would be getting them from St Louis to wherever you are.
Chris McCracken
[This message has been edited by Caver-X (edited 03-27-2001).]
#267215 - 27/03/01 01:59 PM Re: Widest Tire on stock 15x7 wheel
Hunter Offline
Loc: Lyndhurst, NJ
Caver-X, I'm in New Jersey. Give me a good round number for your tires. What type of tires are they? BFG AT KO's or MT?
Alpine Green
520 PIAA Fog Lights
#267216 - 27/03/01 03:35 PM Re: Widest Tire on stock 15x7 wheel
Chris Mc Offline
Loc: St Charles, MO
After doing some math, factoring in the cost of new 32's and what I can afford to pay, I don't think I'd be able to offer you a good price on the 31's once you factor in shipping.
Sorry,
Chris
Chris McCracken
