Originally posted by Nd4SpdSe:
In a sence, yes, but how I see it, and I may be wrong, but "tire+snow=traction" is the same no matter what vehicle the tires are on, no? The tires shouldn't care where the power is comming from.
Having driven almost nothing BUT RWD for my 30+ years of driving, I can tell you that your equation is a bit off. It should be "tire+snow=lack-of-traction". It is true that the tire doesn't care where it is on a vehicle. It will either get grip or it won't. However, as stated, there's a big difference between FWD and RWD. With FWD, your traction wheels are under where most of the weight of the vehicle sits. That helps your traction greatly and why you have the confidence you have driving in bad weather. But with RWD, that exact opposite is true, your traction wheels (while in 2WD) is under the lightest part of the vehicle. That works against you getting traction (and explains why people with pick ups put weight in the back during the winter months). On dry pavement it's not a big deal. However, when you throw in snow and ice, you start losing traction quickly with RWD.
That all being said though, I agree with what everyone has said, the BFG AT/KO's are top picks.
You won't be disappointed with them. I put mine on (265/75R16's on my '03SE as well) late last winter (November/December I think) here in Michigan and was VERY pleased with them over the stock tires. I didn't realize how bad my stock tires really were. I've said in other threads that I used to gun my truck just a bit to get the back end to slip in the snow going around the block because it irritates my wife (just enough to get her to yell at me 'cause she doesn't like it
). With the new BFG AT/KO's, I couldn't GET it to slip under the same conditions! Really, these tires are great in snow. They also last a very long time from what I read and the fact that I got a 60K mile full replacement warranty. That's saying something with AT tires. Most AT's don't come with ANY warranty at all.
So, I hope this helps. You will notice a big difference between your FWD's and your X in the snow (while in 2WD). But, it's not like you will be in 4WD all the time either. It will take time, but you will learn what you can and can't do with it in 2WD. Remember to take it easy with the long-skinny pedal on the right! All in all, these are great trucks in the snow, even in 2WD! And while in 4WD, it can't be beat (my opinion).
-Gonzo
