You might not have to do anything...if you do, maybe a little piece off the ledge where the mud flaps mounted to up front, that's about it.
Just mount them, and turn the wheel, and cut off where it hits if it does...typically the inside corner of that ledge...takes about a minute per side to trim off that notch where the back of the tire swings through.
Enjoy!
Hmmm, and you might have to cut off part of the ARB's wings...ARB's and TJM's need to have parts cut off to avoid larger tire contact sometimes...33's definetely...if these run small, probably not...but check when mounted up....flex it up and make sure you clear the ARB too. (Shrock and Calmini bumpers I think clear w/o trimming for 33's.)
