137
#279001 - 15/08/01 11:44 AM
Re: Shackles and shocks
Loc: Oak Ridge, NJ
I also have the add aleafs for sale, Rancho is no help because they want you to buy their lift from them..not just the add a leafs.
#279002 - 15/08/01 02:18 PM
Loc: Dallas, Texas USA
Originally posted by FSRBIKER: The Fabtech( and I believe ProComp) add a leaves are much thinner than the Rancho's, they probably will not give you as much lift or the same spring rate. There also have been a few that have cracked, Carlton is one that I know of that has had problems with them. I don't have the Rancho part number with me but I don't think that is right.
Correct.. I did have the ProComp AAL and I broke two of them.. Perhaps you will have better luck with the FabTech AAL's. I looked at them and it looks like they would be more difficult to break.
#279003 - 15/08/01 02:28 PM
Originally posted by Goliath The X: Just got my EOE Sliders installed. So, you like those? (All in fun Goliath...all in fun! :D)
Cheers!, -John
#279004 - 15/08/01 02:45 PM
Loc: Houston, Tx.
Originally posted by FSRBIKER: I also have the add aleafs for sale, Rancho is no help because they want you to buy their lift from them..not just the add a leafs. I am also planning on the AALs, but this whole thread has confused me? What exactly is recommended and did anyone find the right part #s? I have tried to hit the extreme 4x4 parts website but it tells me no results are found? I'm ordering my 32"s at the end of October and would like to install everything together?
#279005 - 15/08/01 03:16 PM
Loc: Oak Ridge, NJ
Originally posted by PRIMARYXTC26:
I am also planning on the AALs, but this whole thread has confused me? What exactly is recommended and did anyone find the right part #s? I have tried to hit the extreme 4x4 parts website but it tells me no results are found? I'm ordering my 32"s at the end of October and would like to install everything together? Hmm..website is fine for me www.Extreme4x4Parts.com , they are under Xterra/Suspension. From what I understand they are part of a spring pack and my distributor can get them individually for me...I don't believe that they are available at your local 4x4 shop since Rancho does not list an application. "Correct.. I did have the ProComp AAL and I broke two of them.. Perhaps you will have better luck with the FabTech AAL's. I looked at them and it looks like they would be more difficult to break." A MAXC member has the FabTech's which are a bit longer but thinner than the Rancho's as he can use the load leaf with the stock u-bolts..they have not broke yet but who knows...with the Rancho's you ditch the load leaf...I personally have the Rancho's. [ 08-16-2001: Message edited by: FSRBIKER ]
