Page 2 of 2 < 1 2
#281242 - 13/02/07 05:17 PM Re: 255/85/16
Originally posted by MMNIAC:
...I think 255/85/16s would gain you nothing over say a 265/75/16 which can be run with removal of the mud flaps.
If there are reasons to run a thinner tire when something wider would fit I just haven't seen it discussed in this thread yet.
The biggest reason for not going wider is because you don't have clearance for one.
A 255/85 is taller than a 265/75, but not much thinner (10mm!). I think it's a great compromise and I've seen guys with 33x9.5's out in the woods and doin' great.
Originally posted by TJ:
Even a 285/75/16, which is essentially a 33x11.5...is a better choice, as it requires little to no trimming or turn radius loss, and has the same diameter...with a wider section width.
I assume Jeff is running 255/85/16's of course, as he obviously feels they are better than the other choices he had when picking tires.
Yeah, 285s are nice. Also tougher to fit.
I'm running 35's now. I will post pics as soon as she gets outta the shop! laugh
#281243 - 13/02/07 05:21 PM Re: 255/85/16
Jeff, sounds good!
How come you can't fit 285's though?
#281244 - 26/10/07 10:37 PM Re: 255/85/16
I was looking at this old post of yours regarding 255/85R16 tires. In my research this is the tire I am going to run (i have an '07 4WD S Xterra). I am have installed a 1.5" Calmini Shackles and a 2.5" Rancho quick lift coil shock. Did you do any lifts to get those 33s under your rig ?
thanks
#281245 - 08/11/07 08:03 PM Re: 255/85/16
Snoopy Offline
Loc: San Diego CA
Also running this size tire!
#281246 - 17/11/07 08:07 AM Re: 255/85/16
thanks
255/85/16 fit with no (or very minor) rubbing in the 2nd gen Xs. With what you are running you will fit them perfectly. They are becoming more and more popular in gen2Xs (to TJ's horror).
Here's a couple of pics borrowed from the othe xterra forum
Page 2 of 2 < 1 2
