#28382 - 04/04/08 07:07 AM Trailer Wiring-How to make it neat
Hi everybody,
My wife and I just bought a 2007 Xterra SE. I had a DrawTite hitch added but the wires (4-prong connector) are just kind of "hanging around". I've seen a couple products out there to hide/store the wires but really don't know how they would work or look.
Any suggestions?
Thanks.
#28383 - 05/04/08 05:43 AM Re: Trailer Wiring-How to make it neat
Canope Offline
Loc: Pennsylvania
I used black zip-ties to secure my wires to the hitch. The connector end is then threaded to the two chain-hold holes. It looks 'decent'.
Thomas
"A great civilization is not conquered from without until it has destroyed itself from within."
#28384 - 05/04/08 12:20 PM Re: Trailer Wiring-How to make it neat
cool Get some Black (split), plastic wire bundle shields, at any Auto parts store and wrap the wires with that material, then Zip-tie, like Canope does--
--Do it "UP BEHIND" the lower brackets, so the harness won't be exposed to rocks/bushes-etc !!!
-- [Wave] [Wave] --JIMBO
#28385 - 19/04/08 06:12 PM Re: Trailer Wiring-How to make it neat
I would highly suggest going to a 6 pin or 7 pin RV connection depending on what you're pulling. Nissan sells the little wiring harness or if you have the equipment, cut off the original wiring end and replace it with a deutch or wetherpack connector. That will keep the moisture out of the connection and keep it from rusting. There is lots of room above the spare tire where you can drill a hole in the bumper and install the trailer plug. I did it to mine for under $20 and looks stock and best of all you don't have that damned 4 pin harness dangling around.
#28386 - 27/04/08 04:03 PM Re: Trailer Wiring-How to make it neat
xcanuk Offline
Loc: Mtl. Que. Canada
My X didn't come prewired, bought the kit from Nissan stateside. It came with a simple flatbar with a rectangular clamp. Bolt the bar to the hitch, slip in the 4prong into the clamp.. no fuss.
member of http://www.soxc.org
#28387 - 27/04/08 09:57 PM Re: Trailer Wiring-How to make it neat
just don't do it like this:
