#285161 - 08/10/05 02:17 PM Dumb Spare Tire Question
I have finally decided to upgrade the tires on my 2005 X OR. The primary reason I purchased the vehicle is for getting back and forth to work during inclimate weather (snow). I don't plan on doing any hard-core offroading....yet.
Question is this: is it OK not to upgrade the spare and keep the original tire (the BGF Rugged Trail) and a spare so I don't have to buy an extra tire? I am going to upgrade to Bridgestone Dueler Revos as my main tires.
Thanks in advance.
#285162 - 08/10/05 02:35 PM Re: Dumb Spare Tire Question
If you are going with the same size tires there is no problem with keeping the Rugged Trail as a spare.
This would only be an issue if you were changing tire sizes or you plan on using the spare in your tire rotation.
You will like the Revos a lot better than the Rugged Trails.
#285163 - 08/10/05 07:48 PM Re: Dumb Spare Tire Question
I will make sure I keep the same size.
Thanks for the insight!
#285164 - 10/10/05 05:16 PM Re: Dumb Spare Tire Question
I believe the owner's manual says that you shouldn't include the spare in the tire rotation. the spare doesn't have the tire air pressure sensor in it.
#285165 - 10/10/05 05:29 PM Re: Dumb Spare Tire Question
Understood - I have no intentions on putting the spare in the rotation. I would only use it in an emergency.
