Loc: northern virginia
I was wondering what is the largest tire you can put on a stock X? i've heard people say 30 and 31? i think 31 sounds more right . i had 31's on my pathfinder.
All I can say is ... GO BENGALS!
The 265/75/16s will rub the fuel filler cover on the passenger side. My Trxus in this size rub BOTH sides in the rear when fully stuffed (opposite tire off the ground). I seem to have slightly bent the rear fender under the well molding a bit on the passenger side also. Dont know how it happened- not noticeable... My 2002 has the mudflaps removed, and the fenders are pre-trimmed from the factory. Trimming is easy to do if you need to.
Loc: Greenwood IN
You can fit up to a 32" tire w/ just trimming the mud-flaps/fenders. Swampwrecker is running 33" tires with a T-Bar tweak up front. (Granted, the Super Swampers are narrow. Mehdi needed a 2" Body Lift to accomodate the 33" BFG M/Ts)
