#287094 - 03/04/08 07:46 AM Blower motor resistor did not fix it...
I searched and when everyone else changed their resistor the blower motor worked just fine afterwards. I purchased a new "updated" resistor from my dealer and this one did not solve the problem. So I borrowed one from a known working one and that one did not solve the problem.
The question remains, when the resistor does not repair "only 4 working", what is the next check?
I pulled the control module from the dash and it appears that the switches activate and move correctly.
Thanx!
Any thoughts?
#287095 - 08/04/08 02:20 PM Re: Blower motor resistor did not fix it...
Did the fan motor work at all before the change?
#287096 - 10/04/08 07:34 AM Re: Blower motor resistor did not fix it...
Yes, setting 4 worked prior to and after testing both resistors.
1-3 did not work before testing with replacement resistor, 1-3 did not work after testing with replacement.
#287097 - 10/04/08 09:05 AM Re: Blower motor resistor did not fix it...
I'd have another look at the switch.
