139
#288579 - 24/08/02 02:22 PM
Re: Intermittent rear wiper
Loc: Franklin, NH
My rear wiper switch is a "rocker" switch with the washer side on top and the wiper side on bottom. With ElectroKen's delay installed as he instructed here is the way it operates: When the wiper side is pushed it stays pushed and the wiper cycles initially and repeats every ten seconds. The washer side can be pushed at any time and the washer squirts and the wiper cycles once with each push of the switch. The only trick is that the washer switch must be held just until the wiper kicks in before you release. Then if you want the wiper to keep going every ten seconds you switch the wiper side (bottom) back on........Seems fine to me. Much much better than having the wiper running constantly as Nissan built it. My X is a 2002 and I believe that it was built in August 2001 judging by all the stickers on all the major parts of the vehicle.
Hope this helps.
You can't tell which way the train went by the tracks it left behind.
#288580 - 24/08/02 04:53 PM
After testing the wiper delay this afternoon, here are my results: Wiper toggled: One pass every 10 seconds Wiper/wash pushed and held: Water is deployed and wiper passes every 10 seconds. The wiper 10-second delay works great, but when you want to wash your rear window the water simply streams down the window and onto your bumper, 10 seconds later the wiper activates. I don't know if it would be possible to have varying speeds depending on which way the button was toggled, but that would be ideal. Ken any ideas? BTW, I just wired to the fuse box to test, but where can I find a switched 12V source under there? It all looks like colorful spaghetti to me.
#288582 - 24/08/02 05:50 PM
Loc: Franklin, NH
Dandingo,
Splice the red wire from the delay box to the red w/black stripe wire just under the fuse panel. Don't cut the red/black stripe wire. Just use one of those splice connecters that clamp onto the existing wire. As for the washer, if you push the wash button repeatedly you will get a squirt and sweep with each push of the button.
#288583 - 24/08/02 07:12 PM
Originally posted by Gold Rush: Dandingo,
... if you push the wash button repeatedly you will get a squirt and sweep with each push of the button. Gold Rush- Thank for the tip on the power source, I will check it out. Unfortunately, my wash/wipe switch doesn't behave the way you describe. If I push and hold the wash/wipe, the water starts coming out, but the first pass of the wiper does not occur until 10 seconds after holding the wash/wipe toggle. It sounds as if yours performs a wipe when you initially push the toggle. Edited to add: I found the power source you were talking about, thanks again. Also, my mistake on the wash/wipe toggle...The wiper does pass once when you first push and hold the switch and every 10 seconds thereafter.
#288584 - 25/08/02 06:17 AM
Loc: Shelton, CT
This project can be saved but I need some brave souls with 2002s to perform a daring test. The X must have unmodified wiper wiring with no delay widget connected. Here's the information I need: Remove your rear wiper switch and disconnect the harness from it. Turn your ignition on. With a jumper lead, ground the blue wire in the wiper connector. Tell me: a) Is the rear washer running? b) Is the rear wiper running? Now disconnect the jumper. Again with a jumper lead, ground the blue/yellow wire in the wiper connector. Tell me: a) Is the rear washer running? b) Is the rear wiper running? Disconnect the jumper. Please post the results of this test along with the build date of your X, which is in the driver's door jamb. I will try to get someone a block from me to allow me to do the same test. Everyone say Hi to Wayne, a.k.a. lefty. He is in the XOC and has a yellow 2002 SE/SC. Doesn't talk much though...
#288585 - 25/08/02 09:27 AM
Loc: Franklin Park, NJ
a) blue wire grounded has washer pump only running. b) blue/yellow wire has wiper only running. Build date of my X (Feb 2002) Hi Wayne!
-Bryan
#288586 - 25/08/02 02:50 PM
Loc: Atlanta, GA
for those of us who already have the original box in place, will a fix be a simple one (ie take out the old box, put in a new)?
-dm
"Eat a live toad the first thing in the morning and nothing worse will happen to you the rest of the day." Got a question? You used to be able to ask Brent , but not anymore...
#288588 - 26/08/02 04:36 AM
Loc: Summerville SC
All I can say it delivered as promised. A simple tapping of the washer button keeps the rear wiper on while in the "WASH" mode. I do not want a replacement. Electroken...it works as promised.
I'm a HEATHEN!?
#288590 - 26/08/02 09:38 AM
After re-testing, I found that tapping the wash/wipe does work and that's good enough for me.
Payment on the way. Thanks again!
#288592 - 26/08/02 10:03 AM
Loc: Summerville SC
Originally posted by TatsuoX: Sven, you got mail! Will check when I get home, doing a bad thing, on this board at work
I'm a HEATHEN!?
#288593 - 26/08/02 03:16 PM
Loc: Arvada, CO
just got mine today. was looking through the thread to find any tips and hints before installing and came across the new issue. i guess i'll send mine back to ken and wait for the intermittent wiper widget v2.0. also, i'm a bit challenged when it comes to this stuff. the install instructions say to connect the red wire to "any switched 12 volt source." unfortunately this means nothing to me. anybody got specific how-to instructions? ken, this is a great mod and you are so the man. i can't wait for the newer box. i'm sending mine back today for the upgrade along with a check. you can hang on to the check until i get it installed with a thumbs up if you want. if it works, deposit it, if it doesn't, tear up the check. i kinda doubt the latter will be the case.
#288594 - 26/08/02 05:46 PM
Loc: Windsor Locks, CT USA
Ken, We got ours today. Unfortuantely my brothers truck will not be available as a test platform until at least the second weekend of Sept. (He's moving). I'll hold onto the VERY professional looking mod that you sent me until I hear more concerning the 4 wire set up. My X is a 2001 so I can't do your test on mine Thanks again!
Steve
#288595 - 26/08/02 05:58 PM
Loc: Franklin, NH
ElectroKen,
I'll keep Version 1 as is.
Wiper on: Wiper sweeps every 10 seconds....no problem.
Washer button held: water squirts, wiper sweeps.... hold again....water squirts, wiper sweeps....hold again....water squirts, wiper sweeps....no problem.
#288597 - 28/08/02 08:47 PM
What do you mean by spectacular? What happened? Sparks? Smoke?
-Bryan
#288599 - 03/09/02 03:24 PM
I was never worried Ken
-Bryan
#288600 - 03/09/02 07:47 PM
Loc: Tacoma, WA
Ken
I got version 2 in the mail today and I quickly installed it. I am declaring version 2 a success.
Button pushed up = continuous wiping and washing.
Button pushed down = wiping every 10 seconds.
I will put version 1, along with my $20, in the mail back to you tomorrow.
Thanks for a cool mod, Ken!
Dave
2002 Xterra XE 190K 2012 Frontier S 64K 2007 Toyota Tundra 103K
#288601 - 04/09/02 06:18 AM
Ken, Let me know when you'll be sending out version #2 will ya? Hopefully we'll be able to get it installed right away. Thanks, Steve
Steve
#288603 - 04/09/02 06:27 PM
Ken, I am happy to say that my Xterra now sports an intermittant rear wiper. It works as it should. Thank you very much for your time and effort with this. I'll mail you a check tomorrow.
-Bryan
