1 registered (Tom),
90
#288604 - 05/09/02 12:32 PM
Re: Intermittent rear wiper
Loc: Windsor Locks, CT USA
Excellent.
Steve
#288606 - 20/09/02 05:21 AM
Loc: Massachusetts
Ken You have mail.
The reason why a dog has so many friends is that he wags his tail not his tongue!
#288608 - 22/09/02 07:10 AM
Loc: Baltimore
Ken, my check is now in the mail. Thanks! You ROCK!!
#288609 - 19/12/02 01:56 PM
Loc: McKinney
Hmm, well, not sure how I missed this post, but didn't find it in search until today. (weird.) I was thinking about adding a circuit to the rear wiper as well... but on my 16 hour long drive down to New orleans last week, the entire time it rained, from moderate to hellaceous downpour... so i had some time to think as i dodged soccer moms driving in the thick rain while still talking on their cellphones... If the front wiper delay could be tied to the rear wiper, that would work great for me. Don't have a wiring guide, but would it be as simple as running a relay off the front wiper wiring and interrupting a rear wiper wire? I watched my driving in the rain, and ya know, the rear on my X gets about as nasty as the windshield does at the same time.. so tying the front to back makes sense to me. Not knowing the wiring on the 02's... what do ya think? -=RB42 (PS - I'm a technogeek and love the PIC idea too! But if it's this simple I'd have a hard time going with the controller.
Happiness is found with a larger engine.
#288611 - 20/12/02 06:53 AM
Loc: McKinney
Nuf said... I think I'll save up for one of your modules instead. I guess the current design makes sense from Nissan's point of view... If I had to make as many XTerras as they do, removing extra expense is always a top priority. Thanks for the info Ken - you rule! -=RB42
#288613 - 20/12/02 01:43 PM
Loc: Jacksonville, NC
Web based, I'm assuming?? And let us know as soon as you have a web site set up so we can have a one-stop shop for all of the goodies you have!!!
Never Trust a Helicopter Under 40 - Phrogs Forever
#288615 - 21/12/02 10:02 AM
Loc: Shelton, CT
It's always interesting to see how others have approached similar problems. During a rare free moment I disassembled the original Nissan front wiper delay module. Here are the guts: It's a nice design but probably more complex than it needs to be. It looks like it will last as long as the rest of the truck if the relay holds up. Here is what some of the stuff is: IC1 is the brains, a Microchip PIC16FR711. No doubt chosen for it's A/D converter but has way more pins than are needed here. IC2 is a reset minotor for the micro. This is redundant, the PIC has most of this built-in. IC3 is a voltage regulator The blue thing is a 4 MHz ceramic resonator, the master clock. The box with "3059 BC" on it is the relay that ultimately drives the motor. Q1 is the transistor that allows the PIC to drive the relay coil.
#288616 - 21/12/02 04:09 PM
Loc: Andes, NY
I suggest that if Electroken's Xterra ever dies, everyone here chip in and buy him a new one.
Boldly going nowhere.
#288617 - 29/12/02 05:38 PM
Loc: Longwood, FL
Ken, Check yuor e-mail, just sent you payment via PayPal for the wiper delay module. It looks great! Can't wait to install it! What other electrical mods do you have available for the 2002 Xterra? Thanks, Jim
#288620 - 30/12/02 01:18 PM
Loc: Alabama
How about a Flux Capacitor?
Ian's a genius. I could be wrong.
#288624 - 01/01/03 12:37 PM
Loc: Franklin Park, NJ
How about and auto down feature for other windows? Instead of a 3 position switch like the driver window, we could use a switch where in one position, it would cause the driver door window buttons to act normally and in the other position they'd all be express down. Just a thought. I always wondered why they didn't make this feature for more than one window.
-Bryan
#288625 - 02/01/03 09:38 AM
Loc: McKinney
Any good aftermarket alarm window controller will give you this. Don't need an alarm if all you want is the one-touch.
DEI's is around 90.
#288626 - 02/01/03 03:16 PM
In the switches or the remote?
-Bryan
#288627 - 14/01/03 12:35 PM
Loc: McKinney
Oops... missed your reply... DEI's window controller is about $90 at best buy. It interfaces between the switch and motor, and reads the inputs from the switches, giving you one touch up and down. That's by itself. If you hook up the ground-while-armed (used for starter kill relays, for example), the module will also roll up the windows. If you also hook up a second channel ground input, you can either roll the windows down totally when disarmed, or crack them one inch within 20 seconds of arming. You can insert the module between the drivers door switch and windows, but the passenger window switch will then be on the "motor side" of the wire, and passenger wont have one-touch control. If you run the passenger window wires over to the passenger door and tie the module in there, then passenger would also have one-touch. It's a pain, and most people only connect everything in the drivers door... but it's an option. I don't think there is a suitable ground-while-armed trigger outside the SMART entry module to use this with the factory system. You could use the ground-during-key-lock trigger wire from the front doors to roll them up (its a wire that tells the SMART module you locked the doors with a key). But who uses keys to get into an Xterra anymore? If you want to discuss further, this should probably be a new thread. -=RB42
