134
#291697 - 30/09/02 12:24 AM
Re: Inclinometer
Loc: West Los Angeles, CA
Originally posted by Xterrian: I love Macgyvering crap like this. Originally posted by Xterrian: Is anyone interested in this or should I delete this thread? Don't delete this thread... I like Macgyvered stuff.
#291699 - 30/09/02 08:34 AM
Re: Inclinometer
Xterrian, I've got an old mechanical clinometer/altimeter pod from an older 4Runner that you might be able to hook up some electronical doo-dads to to take a reading from somehow. Hell, you can even see the internals of it here: http://4crawler.cruiserpages.com/4x4/CheapTricks/index.shtml Click on the Clinometer Tweaks link. You want it, I'll send it to ya, no charge. Brent
#291701 - 30/09/02 09:36 AM
Re: Inclinometer
Xterrian, Take a look at this it is a four channel A-D converter. Should do everything that you want. Now with this it connects to Dallas Semiconductors propritary 1-Wire bus but from there you can go to serial or printer port. -Mike
#291704 - 02/10/02 08:59 AM
Re: Inclinometer
Loc: Quebec, QC, Canada
If I understand correctly the principle of the sensor you want to use, it's a glass ampule filled with a conductive solution. There are 4 wires around and one in the center, the more a wire is immerged in the solution, the more current (or voltage) it conduce.
I this correct ? If yes, I can help you with the circuit. Again, if I understand well, you want to do two separate circuit (one for the left-right, the other for front-rear).
#291706 - 02/10/02 10:26 AM
Re: Inclinometer
Loc: Fort Lewis, WA
Thanks to 20-100 and Electroken for responding. I left out the DC killing the sensor part in my posts just to make sure that the person responding knew what the hell they were talking about. I looked into the ADXL202E, but it seemed to me that it was actually an accelerometer and could have problems centering properly if started while on an incline. I may be wrong, but I couldn't get anybody where they were sold to state emphaticaly that this wouldn't be a problem. I'll be happy with a +-2 degree solution, so it doesn't seem like that hard of a sensor to get usable results for me. If it's too complicated to do it myself, I can always purchase their solution for $100. I was trying to keep the project under $100 total. I'll still have to build a serial adapter and buy a serial to usb adapter as well. I'm easily looking at $150 if I go with their solution. There is a downloadable data sheet at the Fredericks Sensors site I posted above, with test circuits and some information that may be helpful in building a reasonable circuit. Electroken, you are the shiznit when it comes to electrical questions here, so if you say scrap it and go with the ADXL202E, I probably will. Let me know what you think. I am probably getting too high tech anyway. What do you think about the gutless servo with just the pot and gears to damp movement?
"The trouble ain't that there is too many fools, but that the lightning ain't distributed right." Mark Twain
#291708 - 02/10/02 01:00 PM
Re: Inclinometer
I bow before you ElectroKen.
And maybe you can answer me: The circuit I was thinking about was derived from a Wheatstone bridge to detect very small changes on resistances between the side pins and the center pins. Did running a very small DC current (in the range of 10 micro amps) can ruin such a sensor ?
#291711 - 02/10/02 02:50 PM
Re: Inclinometer
Loc: West Virginia
Xterrian,
The ADXL202E that Ken suggests is an absolute, not a relative, device. The zero is always "at the same spot". And since it's two-axis, you can also determine your longitudinal pitch, and therefore, with a bit of math, your power...
Regards, Richard.
#291716 - 03/10/02 07:10 AM
Re: Inclinometer
Loc: West Virginia
Originally posted by Xterrian: My power? Okay,okay! Your vehicle's rear-wheel power, then! Regards, Richard.
