#291945 - 03/02/02 09:00 AM Firewall Question for Amp Install
Guth316 Offline
Loc: Atlanta
For anyone who's installed a system in their X, where did you run the power wire (i'll be using 4ga) through the firewall? I'd like to avoid drilling if possible. Any help would be appreciated. Thanks.
#291946 - 03/02/02 09:27 AM Re: Firewall Question for Amp Install
n2 Offline
Loc: Venice Beach, Ca
Just drill through. Its not so bad if you have an automatic. There is a blankout plate where the clutch would normally go. smile
Chris
Chris
2001 XE Silver Ice
www.cmcworld.net <--For pics
#291947 - 03/02/02 09:32 AM Re: Firewall Question for Amp Install
superjens Offline
Loc: North Vancouver
I found a grommet on the passenger side, about a foot down, fits a 6-guage wire perfectly. Just poke a coathanger through the rubber lining on the cabin side and fish away.
#291948 - 03/02/02 10:58 AM Re: Firewall Question for Amp Install
RabidRaider Offline
Loc: Palm Bay, Florida
Ditto, no need to drill. Open your hood and look on passenger side for rubber grommet. Using an xacto type knife cut a small X in the center. Bend a coat hanger out straight (cut the ends of with a pair of dykes to make smooth). Tape the end of amp power cable to one end of coat hanger and feed through (gently). Lay on your back on passenger side floor, reach up under dash and feel around for wire and hanger.
"Instead of getting married again, I'm going to find a woman I don't like and just give her a house."
#291949 - 03/02/02 01:30 PM Re: Firewall Question for Amp Install
gearhead1972 Offline
Loc: Brewster NY
Yeah what he said.... Some people have used the grommet on the drivers side but it is not as close to the battery. The drivers side one is better put to use when you have to run switches in to the cockpit for lights.
Kevin
00' Super Black SE 5 speed
www.rockclmr.com
#291950 - 03/02/02 02:06 PM Re: Firewall Question for Amp Install
mmUTK Offline
Loc: Knoxville, Tn
Also search for firewall. I did mine through driver's side gromment.
http://www.firemarshall.net
