if you want to stay with sony, than you still have a few choices. Here are a couple of them from crutchfield, I assume that you can get a better deal than what they offer, other wise I might suggest a different brand.
Sony's Xplod XM-754SX 4-channel amplifier ($299)
200 watts x 2 in bridged mode
100 watts x 4 into 2 ohms
MOSFET power supply and output stage
front and rear high-pass/low-pass filters variable from 50-300 Hz, 12 dB per octave
line-level and speaker-level inputs
frequency response 20-20,000 Hz
signal-to-noise ratio 100 dB
dimensions:14-1/8"W x 2"H x 10-1/2"D
Sony Xplod ES XM-7547 (Save $270! Was $599.95, Now: $329.95
150 watts x 4 or 360 watts x 2 into 1 ohm
continuously variable high-pass and low-pass crossovers (50-4,000 Hz, 12 dB/octave)
selectable low-cut (subsonic filter) 7Hz-40 Hz with selectable cut and boost (0-10 dB)
103 dB signal to noise ratio
non-negative feedback design for superior reproduction
high-voltage/high-current modes
single-ended push/pull design for stability at 1 and 0.5 ohm
discrete differential inputs for reduced noise
dual power supplies
21"W x 3-5/16"H x 12"D
Kenwood KAC-648S 25W x 4 Car Amp ($199)
2-, 3-, 4-channel, or Tri-Way output
70 watts x 2 in bridged mode
35 watts x 4 at 2 ohms
anti-thump circuit for quiet turn-on
speaker short, thermal overload, and DC protection
extra-large toroidal noise filters
gold-plated preamp outputs
80 Hz selectable low-pass crossover, 12 dB/octave
150 Hz selectable high-pass crossover, 12 dB/octave
10-3/4"W x 2-1/4"H x 11-1/2"D
more kenwood
http://www.crutchfield.com/cgi-bin/S-geopiJh5See/ProdView.asp?s=0&c=3&g=120&I=1 13KAC748&o=M&a=0 http://www.crutchfield.com/cgi-bin/S-geopiJh5See/ProdView.asp?s=0&c=3&g=120&I= 113KACX501&o=M&a=0 Clarion:
http://www.crutchfield.com/cgi-bin/S-geopiJh5See/ProdView.asp?s=0&c=3&g=120&I= 020APX4004&o=M&a=0 Rockford Fosgate:
http://www.crutchfield.com/cgi-bin/S-geopiJh5See/ProdView.asp?s=0&c=3&g=120&I=5 75G14004&o=M&a=0 I personally went with the Clarion APX600.5 (5 channel 600 watts) and love it.
'01 SE 4X4 5-Speed Just Blue
Ski_Racer27@Hotmail.com
AIM: TwinTurbo27
[This message has been edited by ViperX27 (edited 07-23-2001).]
