131
3
#296725 - 17/03/05 08:30 AM
where did you install your amp(s)?
I have one amp installed under the passenger seat but I’m not sure where to install my next amp. With any luck I would like to conceal it somewhere that it won’t be visible.
amp size: ( L x W x H ) 20 21/32" x 8 7/8" x 27/32"
#296726 - 17/03/05 09:43 AM
Re: where did you install your amp(s)?
I couldnt fit my amp under the pass seat, so I installed it on the back of the rear seat on the drivers side.
#296727 - 17/03/05 10:57 AM
Your amp is only 27/32" tall?
#296728 - 17/03/05 01:44 PM
#296729 - 17/03/05 01:54 PM
Loc: North Vancouver
Originally posted by michelin man: sounds "short" But that's only .84 of an inch, and it doesn't fit? I always thought there was more room under the front seat.
#296730 - 17/03/05 06:56 PM
I fit both of my amps under the front seats....I took the seats out to install em..
To make one fit under the driver's seat I had to remove a piece of plastic protecting a wire harness under the carpet.
My amps have a height of 2¼"(57mm)
#296731 - 17/03/05 07:46 PM
the length is what im worried about...
#296734 - 18/03/05 09:51 AM
Originally posted by michelin man: the length is what im worried about... Just for your comparison....Both fit with no clearance issues (I can slide the seat back and forth all the way) Amp # 1 -------- Height 2-1/4" (57mm) Width 12-1/8" (308mm) Depth (w/Mounting Feet) 8-7/8" (225mm) Amp # 2 ---------- Height 2-1/4" (57mm) Width 14-1/8" (358mm) Depth (w/Mounting Feet) 8-7/8" (225mm)
#296735 - 18/03/05 06:27 PM
Originally posted by slantyshanty: here is the mount I made outta 3/4" mdf
Those aren't finished products, but you get the idea. Still needed to cover them in carpet, hide the wires,etc... NICE install!
#296736 - 20/03/05 08:53 AM
Loc: Venice Beach, Ca
You sure that's MDF? Sure looks like particle board to me. In the future, I suggest buying your MDF somewhere else.
#296737 - 21/03/05 05:21 AM
AHHH I stand corrected. Particle board it is! Forgot I used the mdf for somethig else. 10 points to you and your good eyes!
#296738 - 28/03/05 06:44 AM
slantyshanty, very nice install!
#296739 - 28/03/05 08:16 AM
Originally posted by slantyshanty: AHHH I stand corrected. Particle board it is! Forgot I used the mdf for somethig else. 10 points to you and your good eyes! Thanks, I was a high end installer for many years, so I'm pretty familiar with MDF
#296740 - 28/03/05 10:19 AM
#296742 - 28/03/05 11:21 AM
So far not too much. Just the little plastic light cover on the inside of the hatch. Took care of that though. Then again I only have about 6k miles on it, so stuff hasn't had a chance to rattle apart yet That, and I don't have the subs in all the time. Have to take them out when I take my dogs out to the beach or where ever.
#296743 - 29/03/05 08:37 AM
#296745 - 17/01/08 06:43 PM
Mine needed to be out of the way. And this was all I could think of. It works great. //imageshack.us] [/URL]
