137
#306239 - 16/11/07 12:22 AM
plans of attack
been thinking about swapping out my 04 RF HU for a NAV. need your input, suggestion or anything you all can recommend.
04 SE w/ Rockford Fosgate and OEM AMP, SUB
here are my choices/plans:
1 x Eclipse AVN2210p 1 x SWI-ECL2 (to retain my steering wheel control) 1 x PAC OEM-2 (to utilize the AVN2210p w/ OEM AMP)
i'm certain the SWI-ECL2 is a must but unsure if the OEM-2 is needed.
anything i'm missing or do not need? thank you all in advance
#306240 - 16/11/07 01:00 AM
Re: plans of attack
I got the eclipse head unit I love it
#306241 - 19/11/07 07:05 AM
Re: plans of attack
Yes, you do need the OEM-2. It takes the speaker level outputs from the Eclipse and reduces them to a level that the Rockford amp can accept as an input. You may also consider replacing some speakers; at least the ones in front. Even spending $50 on a new pair up there will dramatically improve imaging and clarity.
#306242 - 19/11/07 03:49 PM
Re: plans of attack
thank you! what would you recommend for the front pair? i was thinking of the sony gt1625a
#306243 - 19/11/07 04:14 PM
Re: plans of attack
The front speakers are 6x9, so look for those... in the sub-$100 range I would recommend the Infinity REF9613I, which are only $70 at crutchfield.com right now. Other brands to consider are Alpine, Boston Acoustics, JBL, and Polk. Other brands are okay, but generally unpopular (usually for a reason). Best bet would be to go to a local stereo shop and listen to some different brands to figure out what sounds best to your ears.
#306244 - 20/11/07 08:15 PM
Re: plans of attack
oh.. i thought the fronts are 6 1/2" and the rears are in the combination of an 8" sub, a 3" mid and a 6x9 no?
#306245 - 20/11/07 08:26 PM
Re: plans of attack
blue you are correct, fronts 6.5...back 6x9 with a sub...I was thinking it was a 10"...wheres the 3" mid at?
#306246 - 20/11/07 08:36 PM
Re: plans of attack
Originally posted by BossMan: blue you are correct, fronts 6.5...back 6x9 with a sub...I was thinking it was a 10"...wheres the 3" mid at? this picture was taken by a ebayer. i just saved it for reference
#306247 - 22/11/07 07:08 AM
Re: plans of attack
The Speaker set up above is from a Rockford Package -
you will know if you have that package, as you will see a big box for the sub on the Drivers side of the hatch area.
As an added note - if your replacing your front speakers - the 2002-2004 stock fronts have the spacer built in, so you will need to get a spacer for your replacements !
#306248 - 22/11/07 07:44 AM
Re: plans of attack
Loc: Georgia
Though the installs aren't exactly the same in some respects, here is my speaker replacement thread in case it's useful. The headunit in my 2002 is absolutely identical in appearance to the RF system, has a 6-CD changer & steering wheel controls, everything - it just doesn't say "Rockford Fosgate" on it and I don't have a sub. What's the diff between this and the RF system besides no sub? And would the equipment listed by the thread starter work in my truck?
#306249 - 22/11/07 11:59 AM
Re: plans of attack
Originally posted by Canadian5150:
As an added note - if your replacing your front speakers - the 2002-2004 stock fronts have the spacer built in, so you will need to get a spacer for your replacements ! dang it! thought it would a direct swap. oh well, where can i find the spacers? can i use the oem? What's the diff between this and the RF system besides no sub? And would the equipment listed by the thread starter work in my truck? thank you for the thread. bookmarked it. as far as your non-RF HU goes, i'm sure the equipments i listed will be compatible with yours as well. but i don't think you will need the OEM-2 because you might not have an OEM AMP to utilize it with. i'm not quite sure though. don't think there are any differences between a in-dash 6 disc changer HU and a RF HU functionality wise.
#306250 - 22/11/07 04:25 PM
Re: plans of attack
Loc: Austin, TX
Originally posted by -Will-: The front speakers are 6x9, so look for those... in the sub-$100 range I would recommend the Infinity REF9613I, which are only $70 at crutchfield.com right now. Other brands to consider are Alpine, Boston Acoustics, JBL, and Polk. Other brands are okay, but generally unpopular (usually for a reason). Best bet would be to go to a local stereo shop and listen to some different brands to figure out what sounds best to your ears. He has a first gen not a second gen
#306251 - 23/11/07 02:36 PM
Re: plans of attack
Originally posted by Big Daddy Chia: He has a first gen not a second gen eep, didn't notice that... i'm a moron!
