#306633 - 12/06/03 10:46 AM Window wireing question
CDLXterra Offline
Loc: Oregon
I have a 2000, im not sure what the other years are like, but when i like the windows from the drivers seat you can't even control. It seems to me like it should be you lock them so other people cant control it but you can. Does anyone know anyway to change the wires around so you can do that, or is it way too much work?
#306634 - 12/06/03 11:07 AM Re: Window wireing question
njs1stlt Offline
Would love to help but I have no idea what you just said.
#306635 - 12/06/03 11:26 AM Re: Window wireing question
Olegkha Offline
Loc: Brooklyn, NY
I think he wants to lock out the passengers from controling the windows, and controling them him self ONLY
the lock button on the drivers side door will LOCK OUT EVERY one including the driver
#306636 - 12/06/03 02:27 PM Re: Window wireing question
njs1stlt Offline
Ahhh, I see hmmm...Electroken?? I suppose
#306637 - 12/06/03 06:37 PM Re: Window wireing question
CDLXterra Offline
Loc: Oregon
yea sorry if i was a little unclear but Olegkha said exactly what i ment in like 5 words. wonder if electroken would know how to do this...
#306638 - 12/06/03 07:42 PM Re: Window wireing question
Robert C. Offline
Loc: Alabama
It seems like it should be a fairly simple modification (thinking about it, anyway, not actually getting to all the wires). If you think about it, all the wires (excluding the ones to the driver's window) go through that switch. The driver's side switch has one wire coming in from an ignition-switched positive source (may be negative, but I doubt it) and the other goes to the window motor. The other switches (on the driver's door and all the rest of the doors) must have one wire running from the ignition (quite possibly branched off of the same wire that runs to the driver's switch) to the lock-out switch, and then to the switches and on to the motors. Therefore, you could, most likely, remove the leads from the lock-out that go to the driver's panel and wire them directly to the wire that is always on with the ignition. I'd try and draw up a diagram if I had a place to post it. Anyway, that's how it seems it should be. However, knowing Nissan it's probably run through a gazillion relay and other switches before finally performing its function.
However, if you don't plan on ever using the switches on the passenger doors you could always just unplug the wiring harnesses from the switches you don't want anyone to use. However, this will mean that you can only operate those windows from the driver's door (assuming the switches aren't wired up all funky and the driver's switches rely on the other switches).
#306639 - 13/06/03 12:13 PM Re: Window wireing question
rb42 Offline
Loc: McKinney
Unless 2000's are different, the power windows are wired in a manner similar to the 5-wire door lock systems, meaning the switch at the door is part of the circuit path for the motor, and removing it would defeat the window motor for both switches...
-=RB
