WARNING-LONG AND BORING
Ok, 2003, SE, SC 4x4(not that it matters)
Had it about 40 days and had 6 CD's in the changer..the other day I hit the CD button to activate it and it started clicking and clacking then "ERR3" shows up on the readout. Being the genious I am I figured the ERR part meant error. Well, I couldnt get any CD's to play nor could I get them to eject.
Did a google on ERR3 and the only thing I could find was a Lexus group like this one where guys were complaining that if it happened, the dealer will replace it cause it's shot. I took it a step further and emailed Rockford/Fostgate tech support and this is what they have said.
Here is the back and forth:
Hi
I received an "err3" code on my RF cd player today and now it wont play cd's or
eject them. Any help?
Mike
Response (Jeff) - 06/19/2003 09:03 AM
What I would recommend trying first would be using the reset button on the head
unit. It is behind the faceplate on the lower left have side. That will
completely reset the unit, and should fix the problem. You can also try a
cleaning CD to see if that will help with the problem.
Thank you
Ok, guess Im not as smart as I thought I was! I cant seem to remove the faceplate to hit the reset button. Its installed on a 2003 Nissan Xterra. I cant use a cleaning CD because its a 6 changer and I already have 6 in that I cant get out.
Mike
Response (Jeff) - 06/20/2003 08:48 AM
Mike,
If it is a Rockford CD changer than the reset button will be under the sliding
door for the CD magazine to be put in. That can be pressed with a ball point
pen, and that will reset it.
Thank you
END OF BACK AND FORTH
Obviously it DOESNT have a reset pin/button or whatever....though I am impressed they emailed....
Other then taking it to the dealer, any suggestions?
Boy, I forgot how boring radio was.....
BluRdgX
