#311052 - 18/02/05 11:20 AM X is gone, T is here! (alarm tips?)
rb42 Offline
Loc: McKinney
Traded the X in yesterday on an 05 Titan.... was kinda sad to see it go, but all i had to do was drive the titan again and that sadness dissappeared. smile
So, I pulled the bass shakers and DEI remote start system out of it this morning (it was really easy to do), and it's going into the Titan soon.
Anyone installed in a Titan yet? Any tips on good hiding areas, where to grab wires, etc? This is a base model with no power anything... not even keyless or power windows (but it has cruise, weird huh?)
Oh, I guess I can finally fess up - I am the one that created the alarm install guide on the xterrafirma website a couple years back (and the fender resonator removal guide). I didn't wanna say anything since it was my personal vehicle back then, but it does not matter now I suppose. smile
Thanks in advance for any help...
-=RB42
#311053 - 18/02/05 12:57 PM Re: X is gone, T is here! (alarm tips?)
here ya go
the cut and paste didn't do very well, sorry
12volts green (40A) + ignition harness
Starter brown + ignition harness
Second Str. lt. grn or blue/grn + ign. harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory purple + ign. harness
Keysense red/blue to black/red + ign harn or BCM R of column, pin 37
Power Lock blue - driver door module in door
Power Unlock red (double pulse) - driver door module in door
Lock Motor purple 5wi BCM to right of column, pin 65
Unlock Motor green 5wi BCM to right of column, pin 59
Parking Lights+ red/blue + dimmer switch on dash
Parking Lights- N/A
Hazards white/black - BCM to right of column, pin 29
Turn Signal(L) green/black + BCM to right of column, pin 60
Turn Signal(R) green/yellow + BCM to right of column, pin 61
Reverse Light green/white + inside rearview mirror
Door Trigger see notes - BCM to right of column
Dome Supervision blue - BCM to right of column, pin 63
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse on power unlock
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire red/green or red/black + brake pedal switch
Parking Brake green - parking brake switch or cluster
Horn Trigger red/white - steering column
Memory Seat 1 lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
#311054 - 18/02/05 04:39 PM Re: X is gone, T is here! (alarm tips?)
panhandleX Offline
Loc: Panama City, FL
What kind of trade in did you get for your X? I'm seriously thinking of trading mine for a Titan as well.
I thought I knew ridiculous, until today.
#311055 - 19/02/05 03:07 AM Re: X is gone, T is here! (alarm tips?)
lol I just sold my Titan to buy my X.
You can find all the answers to your Titan questions (and great forum too) at www.titantalk.com
Best place on the web for the Titan.
PS...make sure you put synthetic oil in your rear differential if it hasn't already been done.
