#312598 - 14/04/01 11:00 AM Turn Signal Problems
livinx Offline
Loc: Derry,NH
Does anyone know where the turn signal relay is located? I went offroading last week and got the engine a little wet. On they way home my turn signals stop worked. The fuse had blown, I replaced it and it blew again. All the lights and other electricals work fine. The hazards work fine, just the turn signal fuse keeps blowing. I suspect the relay may have gotten wet, but I do not know where it is. Help.
2000 Silver 5spd 3pak
"Reality is what you make of it."
#312599 - 14/04/01 07:36 PM Re: Turn Signal Problems
ElectroKen Offline
Loc: Shelton, CT
The flasher is inside the truck, roughly behind the radio. I doubt that it's bad because it is shared by the hazard circuit, which you say is working correctly.
The turn signal switch in the column may be bad or one of its wires may be chafed inside the column. The green wire to the switch would be most suspect.
Another place to look for a chafed wire would be the red/yellow striped wire to the hazard light switch.
#312600 - 14/04/01 07:39 PM Re: Turn Signal Problems
xterraintx Offline
Loc: Eddy, TX..
ElectroKen I am sure glad you monitor us dumbsh#$@ Thanks....
SWXC member #37
TMTC member #951
