#312807 - 17/03/02 04:55 PM Head unit install question(s)
Nimic328 Offline
I got Pioneer DEH-7400MP head unit installed and it works, but I have 2 concerns.
1. In n2's post entitled "Complete wire list (includes radio)," he states that the blue/red wire is the dimmer. While this seems to be true, what is the pink/black wire for? I haven't been able to figure it out. The reason I ask is that my head unit has a wire marked "Illumination", instructions say to connect it to lighting switch terminal. I connected it to the blue/red wire, but I am wondering if I have made a mistake... Any ideas?
2. I couldn't figure out how to use the cage that came with the Pioneer head unit, so I installed it using the factory bracket. Though its very secure, I don't like the way it sits in the middle of the hole. Can anyone give me some brief instructions on how they installed the cage in their X?
Thanks in Advance,
CB.
#312808 - 17/03/02 06:37 PM Re: Head unit install question(s)
RabidRaider Offline
Loc: Palm Bay, Florida
2001 Nissan Xterra Wire Colors
Wire/Function.....Color.....Location/Description.....Polarity
12 Volts.....White/black.....Ignition switch.....+
Accessory.....Red or red/yellow.....Ignition switch.....+
Ignition.....Black/white.....Ignition switch.....+
Starter.....Black/green or green/yellow.....Ignition switch.....+
Starter2.....Black/ yellow.....Ignition switch.....+
Brake Switch.....Brown/red.....At switch above brake pedal.....+
Dimmer.....Pink/black.....At any illuminated switch in dash.....+
Parking lights.....Blue/red.....Drivers kick panel.....+
Doorpin.....Red/black***.....Pin-9 on Smart entrance module**.....-
Factory Alarm arm.....Yellow****.....Pin-30 on Smart entrance module**.....-
Factory Disarm.....Yellow/red****.....Pin-31 on Smart entrance module**.....-
Hand Brake.....Yellow or gray/blue.....At switch on hand brake lever.....-
Headlights.....Red/black.....At steering column.....-
Hoodpin.....Black/pink.....Pin-29 on Smart entrance module**.....-
Rear hatch pin.....Common with doors
Horn.....Lt. Green/red.....At steering column.....-
Reverse lights.....Yellow/red.....In driver’s running board.....+
Tach.....Blue*.....At distributor front of engine*.....AC
Key sense.....White/green.....Pin-24 on Smart entrance module**.....+
Speed sense wire(VSS).....Green/black.....Pin-37 behind instrument cluster*****
Lock.....Lt Green/red.....Pin-18 on Smart entrance module**.....-
Unlock.....Brown.....Pin-19 on Smart entrance module**.....-
Driver Window up.....Blue.....At master switch.....Rev. pol
Driver Window Down.....Blue/black.....At master switch.....Rev. pol
Passenger Window up.....Blue/yellow.....At master switch.....Rev. pol
Passenger Window down.....Blue/white.....At master switch.....Rev. pol
Left Rear Window up.....Green/red.....At master switch.....Rev. pol
Left Rear Window down.....Green/yellow.....At master switch.....Rev. pol
Right Rear Window up.....Green/white.....At master switch.....Rev. pol
Right Rear Window Down.....Green/black.....At master switch.....Rev. pol
* Same for both 2.4L and 3.3L. Tach can also be referenced at Pin-3 on the ECM at front of center console
** Located above drivers kick panel
*** On models without power door locks, this wire can be found in the drivers kick panel.
**** These wires will also operate the door locks. Double pulse yellow/red for unlock.
***** Also found at Pin-7 of the ASCD module on the left side of the steering column.
"Instead of getting married again, I'm going to find a woman I don't like and just give her a house."
