#313672 - 05/03/01 01:31 PM CB and FM antennas
PatentCowboy Offline
Loc: NYC, NY
Does anyone know about a FM reception booster or aftermarket antenna to imiprove reception? I have a station that I like that just barely comes in.
Also, what type of antenna mount do y'all use for a CB? I am in New York City, and need to get into parking garages. I have a handheld unit, but want to mount an external antenna for road trips.
PatentCowboy
#313673 - 05/03/01 08:12 PM Re: CB and FM antennas
gearhead1972 Offline
Loc: Brewster NY
Check out XOC's(Ian) setup it should work for you. I'm shure he will be by soon to give you the URL
Kevin
00' Super Black SE 5 speed
31" BFG M/T's, ARB, Rancho RSX's
superblackxterra.tripod.com
Kevin
www.rockclmr.com
#313674 - 05/03/01 11:59 PM Re: CB and FM antennas
defibvt Offline
7
Loc: AZ
Hey, the first link is Ian's set up look under modifications. The second link is where I found the bracket and the third link is where I found the easy over.
http://www.xterrain.com/ Ian's set-up
http://www.alfenterprises.com/mobile1.htm bracket part # MK-204R
http://www.wearecb.com/mounts.htm#Select
easy over part #Valor 203EZ
Hope this helps.
There are only three sports-Mountain climbing, bullfighting, and motor racing-all the others being games. --Ernest "Papa" Hemingway
#313675 - 08/03/01 09:40 AM Re: CB and FM antennas
defibvt Offline
7
Loc: AZ
Did it help?
#313676 - 09/03/01 12:41 PM Re: CB and FM antennas
Loc: NYC, NY
Yes, thanks.
I just got a Midland 75-822 and will work on mounting the antenna.
#313677 - 16/03/01 07:56 AM Re: CB and FM antennas
Loc: NYC, NY
If I use a magnetic mount antenna, and put something under it so it won't scratch the roof, will that ruin my ground plane?
