Originally posted by Yasha:
Exactly what i am thinking. What I want to do, once I am done with school and have a job, I'll replace the back with Alcan leaf's and then switch out the front. with radflo's. I am on a budget crisis, so I need to sell them as it is not bad right now. We'll talk at the meeting.
No need for Radflos unless your going to add more weight to the noise, start running faster, or jumping. Only thing you can add is more wheel travel with the Radflows (about 0.75") and about another 0.75" of trave changing the UCAs also. That will run you about $1,300+ from PRG I think (don't quote me). Overall gain is about 1.5" of wheel travel downwards. No other gain can be made. Now... Adding an aftermarked bumper means you need to change your front coils, so than new coilovers become cost effective, and the added UCAs are a bonus.
Or... A drop bracket and you can get crazy high, needing coils and could also uses spacers too depending on the overall lift height or ride you are looking for (adding the spacers can reduce preload, but I'd recomend keeping you're swaybar than, defeting alot of the purpose).
Oh... Cheap trail bang for the buck for more wheel travel... Remove the nuts that hold the front sway bar in place. BUT ONLY on the trail. I would not recomend this on the road without a custom setup. Just follow behind me when I take a turn faster than 10mph to see what I mean.
-MadManX
