103
#391851 - 10/03/04 08:06 AM
4x4Rockshop.com!!!
Loc: Suffolk County,NY,USA
I ordered a 150psi fixed CO2 regulator from them and got incredible service. I ordered it over the phone, they took all of my info including my email address. They sent me an email later the next day with a PDF file attached, which was my invoice. They tried to send me my UPS tracking number but the email bounced, so they actually called meto tell me that the email bounced and to give me the tracking number. I have ordered several hundred, maybe thousand at this point, dollars of aftermarket items from all of the major Nissan aftermarket manufacturers, and havent gotten anywhere near the service I got from 4x4rockshop. They emailed me, called me, the item was shipped out and I received it, all exactly when they said. Great company I highly recommend them!!
#391852 - 10/03/04 10:13 AM
Re: 4x4Rockshop.com!!!
Loc: TinleyPark, IL.
Ya, I ordered a powertank system from them last year, it came a day or two late due to a screw up in there system. They explained what went wrong and how sorry they were... They gave me a free regulator bag for my troubles. I would recommend them and purchase from them again.
#391855 - 10/03/04 03:41 PM
Loc: Tacoma, WA
They give free shipping on SR skidplates, so I ordered two skids from them. No problems at all. Great company.
2002 Xterra XE 190K 2012 Frontier S 64K 2007 Toyota Tundra 103K
#391856 - 10/03/04 07:21 PM
Do not know about C02 rotting tires but since atmospheric air is about 78% Nitrogen, I would see no problems with using Nitrogen gas instead. Did you ask him what the price difference was?
#391858 - 10/03/04 08:55 PM
Originally posted by xterrah: Package B shows a picture of the "Tire Inflator With Gauge." You clip it onto the valve stem and inflate directly through the gauge which allows you to read the tire pressure while inflating. However, under 'Package Includes' it lists "Air Tire Pressure Gauge," which is another product they sell that only reads the tire pressure.
If I found what you were talking about, it looks like a "fancy" tire gage. Including links help make sure everyone is on the same page. I don't see where it would plug into an air source. I think this is what you are looking for. I have the upper/right one. But I did swap the gage from it's orginal 0-160 to one that read 0-60. FWIW, the Staun deflators aren't worth the brass they are made out of. I have found them anything but repeatable. Originally posted by xterrah:
Has anybody heard of CO2 diminishing the integrity of tires or of using nitrogen as an alternative for CO2 in tires? I've been using CO2 in my tires for 2 years and it hasn't done dick to my tires, but I also been replacing tires anually. Ask yourself, would people sell CO2 for this application if it ate tires? Nitrogen could be used as well, the aircraft industry uses it in tires.
#391862 - 11/03/04 07:01 AM
With using Nitrogen instead of CO2 for filling tires. Isnt Nitrogen stored at higher PSI (3000psi?) as opposed to CO2 (1200-1800psi). Doesnt that pose a greater risk if it were dropped, truck rolled, valve knocked off, etc?? Just curious, I am very happy with my Bar hookup's CO2 setup. I dont plan on ever going to Nitrogen. I also have the adapter for hooking my CO2 tank/regulator to a keg. When I'm having a BBQ I'll put a 1/4 keg on ice and hook it up to the CO2 tank. Nothing is better than beer on tap. I am so obsessed with this now that I drilled a hole in my wine cooler/fridge (no freezer) and run a quarter keg or 5 gallon keg (depending on my mood/parties) of John Harvard's all of the time. I rotate every month with a different brew. Great alternative use for CO2 when not offroading!!!
#391863 - 11/03/04 07:03 AM
I understand what you are talking about now. That bitch! It looks simple enough to answer if they take the time. The inflator still looks a little funky. The shrader valve is a stupid way to feed air into it. I have quick disconnects on all my Powertank stuff so it positively locks. The airchuck/guage doesn't take an extra hand to hold onto the air hose.
#391864 - 11/03/04 09:45 AM
Loc: san jose, CA, USA
Originally posted by xoc: Originally posted by xterrah: [b]You clip it onto the valve stem and inflate directly through the gauge which allows you to read the tire pressure while inflating. Regardless of what they call it, it doesn't work well.
Much faster to just air up, eyeball it, and check it a few times.[/b]Here's a quote from the link for the inflator/gauge: "Please note that the gauge will not show actual tire pressure while inflating. Actual pressure is shown while the gauge is clipped to the valve stem and the tire is not being inflated." I bought a similar POS (Viair) & never used it once I realized it didn't work how I though it would. I finally ended up purchasing one of those heavy duty gauge/inflators you typically see at service stations, the kind with the reddish rubber hose & pop-up brass pressure gauge (Sears); just conect to source hose with quick connect & squeeze the trigger to inflate, and when the trigger is released, the brass rod shoots up & gives approximate pressure. I realize it's not incredibly accurate/precise, but I feel it's good enough in most cases & will certainly take abuse. Found a pic from Sears.com:
#391865 - 11/03/04 09:48 AM
I had one of those before I bought the powertank one. I didn't like the popout pressure reading. And it doesn't clip to the tire stem.
#391866 - 11/03/04 10:15 AM
Originally posted by Aero Steve: I had one of those before I bought the powertank one. I didn't like the popout pressure reading. And it doesn't clip to the tire stem. True enough; however, (1) it could be retro-fitted with a clip-on fitting, as I did with my tire deflator, and (2) the clip-on I retro-fitted onto my deflator has clearance issues with the stock rim design & has to be positioned-just so to stay clipped on (good thing I'm airing down anyways cause I lose lots of PSI just fumbling trying to get the clip-on fitting to stay clipped on!!!); however likely my clip-on fitting is simply a cheap POS & there are better ones out there...which could be fitted to inflator. Hmmm...with Powertank it shouldn't be much of an issue (clip-on vs. no) as the tires are inflated PDQ, no???
#391867 - 11/03/04 12:30 PM
Originally posted by xoc: Originally posted by xterrah: [b]You clip it onto the valve stem and inflate directly through the gauge which allows you to read the tire pressure while inflating. Regardless of what they call it, it doesn't work well. I have that guage, and it takes 5 times longer to air up a tire through it, as opposed to without it due to how restrictive it is.
Much faster to just air up, eyeball it, and check it a few times.[/b]Yeah, that makes sense. Here is a random link I found describing it as “100 psi steel case.” That would override any benefit of having a 150 or 200 psi regulator. http://www.getagauge.com/ Here are regulators with the valve built in and they are adjustable. However I don’t see a bleed button on either of them. And more $ of course. http://www.4x4rockshop.com/scripts/prodView.asp?idproduct=2171 or http://www.4x4rockshop.com/scripts/prodView.asp?idproduct=2172
#391868 - 11/03/04 06:55 PM
Loc: In a Bar near YOU!
i dont know much about Nitrogen vs CO2 all i know is that in my paintball gun i have a Nitrogen tank and system on my A-5 for the winter and a CO2 tank for the summer. Otherwise the blowback valve doesnt work correctly.
I know one thing the Nitrogen tanks are way beefier and thicker than the co2 tanks. Also i can get through more games with a nitro tank than with a co2 tank.
.:SpaceMonkeyMafia:.
#391869 - 11/03/04 08:04 PM
Loc: Birmingham, AL
Thanks for the good words, folks.
Now I feel I must address xterrah.
I heard word for word the entire exchange from Jenifer yesterday. She did tell you right off that if you had technical questions she could not help you. She handles the orders, puts in PO's, handles problems and is basically indispensable to me. But ask her about specifics on the site and that's just not her bag.
What IS her bag is going far out of her way to help our customers out, as you can see from the other posts.
In reading your email that you sent her I was also confused as to your question. You apparently kept asking about which guage came with the package and Jenifer kept assuring you it was the one in the photo on the page. When she told me what you kept saying I didn't understand the issue, either.
I then reread it a few times and finally realized that what you must have meant was that the description just said gauge and not "inflator." The guage in question does include the ability to inflate through the guage, unlike other guages we sell. The description apparently just wasn't clear enough so we changed it this morning.
I guess that was what the issue was?
I wish you would have just left me a message to call you back. I was in Detroit for the day and was unable to check emails but I did have time to make a few calls. Would have happily handled it.
So I did email you this morning but didn't hear back from you. I have the guage and Stauns boxed and ready to ship but was waiting to hear back from you so they are still here, pending confirmation that this is, in fact what you wanted.
As you can see by the time of my post, I work long hours to handle our sales and our customers and I really try hard to do everyone right - the way I like to be treated when I shop. I am sorry you had a communication problem yesterday.
Oh yeah. That said, I'd really appreciate it if you would refrain from calling my wife a bitch. She's really quite a lovely woman and the light of my life.
2002 SE Super Charged - Just Blue
#391870 - 12/03/04 01:12 AM
Originally posted by TXJEEPER: Oh yeah. That said, I'd really appreciate it if you would refrain from calling my wife a bitch. She's really quite a lovely woman and the light of my life. I think someone owes you and your wife an apology! You're being awfully nice under the circumstances! Keep up the good work! Hopefully I'll be able to do business with you soon. We appreciate people like you who make the extra effort!
#391871 - 12/03/04 09:53 AM
Loc: Birmingham, AL
It is unfortunate that there was an apparent miscommunication between you and our company. We try our best to treat our customers with respect
#391872 - 12/03/04 10:01 AM
Loc: ATX
Originally posted by 4x4ROCKSHOP.com: It is unfortunate that there was an apparent miscommunication between you and our company. We try our best to treat our customers with respect I don't want to get into the middle of this, but it seems like Mike has gone above and beyond what any other manufacturer/sales department has done (no offense CALMINI or Shrockworks)... I would hate for there to be any bad blood between any of us... Xterrah may have a valid complaint, but it doesn't really seem that the mud slinging should be conducted here on this board... It just seems that if there is/was an issue, it should be mentioned on here, then when/if the issue is resolved, that should be mentioned also... that is just my opinion, FWIW... and calling anyone's spouse a bitch is just wrong... it's too small of a world and it might just come back to bite ya right in the ass!
XOCEverything you need, if you don't mind the b.s.West Ham UFC -- Come On You Irons!!! www.myspace.com/kraigslist Kraig
#391873 - 12/03/04 10:14 AM
Loc: Wisconsin
Originally posted by xterrah: Simply put -- is it the one in the picture or the one in the description. "They are the same." No, they are not the same. Let me send you the links to the two items and you can tell me which one. Hence a quick e-mail to her saying "here are the links." I called immediately after I sent the e-mail so I could be on the phone as she opened the links to discuss them. Instead, when I called back she kept insisting "they are both the same." [The same as what? The one in the picture or the one in the description]. You do not say to a customer with impatience "I am not going to keep beating a dead horse." Finally I said please just open the links to the items and you will see what I mean. She then opened them and realized that the description of the item WAS different than the item pictured (as evidenced by the fact that you changed the descripion on your webpage). Rather than saying "Oh, I see what you mean." She made some excuse about "just because the descripion is different than the one in the picture ..." [implying, you're an idiot].
No, the issue was not the gauge, it was the attitude I received from her. Under no circumstances do you treat a customer with impatience and with a higher than mighty attitude, even if you think the customer is wrong. Just because she is your wife that does not make it okay for her to treat your customers with anything but respect, which she showed none. Trust me, I am not making this up because I have nothing better to do.
Again, if she didn't know the answer or couldn't understand my question, she should have said so. That was her judgment call. I don't know what she knows and what she doesn't know. I would have had no problem waiting a day for the answer. I would have preferred that rather than incurring phone charges from California to Alabama while she just didn't get it and didn't even try to get it. I had to insist she open up the links I sent her.
I guess we can now see the philosophy of your company. If things go wrong or if there is a communication problem, the customer is never right. I'm sure your wife is a lovely person but maybe she should stick with filling orders and not *customer service.*
A more professional response from you would have been "It is unfortunate that there was an apparent miscommunication between you and our company. We try our best to treat our customers with respect, etc."
In response to your anticipated reply, you're right and I am wrong. I am only the customer, what do I know. All of that bullshit and you couldn't even apologize for calling his wife a bitch? Be careful where you use the word "We". I think that 4X4rockshop has went way out of their way to satisfy you and I would give them my business anyday.
#391874 - 12/03/04 10:17 AM
Loc: ATX
Dammit, Ian... why in the hell can't I delete my own dumbass post anymore?
#391875 - 12/03/04 10:20 AM
Loc: Wisconsin
Originally posted by xterrah: I called today to be sure I was getting the Inflator Gauge since I already have the Pressure Gauge. Mike was out and Jenifer was there by herself. She is a real beaoch! All I wanted to do was confirm that I was getting the "inflator gauge" and not the "tire pressure gauge." In my book "beaoch" = bitch
