Page 10 of 10 < 1 2 ... 8 9 10
#392945 - 08/03/06 11:29 AM Re: 2005 Xterra Front Bumper
Rear bumper picture bump!
I am looking forward to some pictures as soon as you have them.
#392946 - 23/06/06 03:40 PM Re: 2005 Xterra Front Bumper
who's x is this?
#392947 - 03/07/06 01:33 PM Re: 2005 Xterra Front Bumper
That is my 05 OR. The pic is from the power lines in Hampton, NH.
#392948 - 03/07/06 06:47 PM Re: 2005 Xterra Front Bumper
sweet looking X!
#392949 - 06/07/06 02:30 PM Re: 2005 Xterra Front Bumper
Anyones bumper not line up even. Mine is a little to the driverside. Its real close on the pass. headlight and has some distance between the Dr. light. I mean side to side. My up/ down is level... I do not know if I should contact Jim or just leave it. Its like the brackets were not 90 degrees to the frame. Thanks
#392950 - 07/07/06 09:51 AM Re: 2005 Xterra Front Bumper
Mine was fine.
#392951 - 07/07/06 11:42 AM Re: 2005 Xterra Front Bumper
Mine was off like you indicate. Spoke to Jim about it and he said they see that from time to time and probably is the alignment of the body to the frame.
I took my bumper off and on 3 times trying to get it more even with no luck initially.
To move the bumper out on the passenger side I bought some stainless steel washers and shimmed the bumper brackets out and that helped a bunch. I only used one washers on each front bolt mount on the passenger side and that did the trick. Everything cleared and looked better.
The 30mm long bolts supplied were too short so I purchased some 40mm bolts so I still had enough bite into the frame mount. You could also go with 35mm and they would work.
As to the fact the bumper sticks out more on the drivers side I think you would have to shim between the bumper and the brackets but I did not bother.
#392952 - 08/07/06 11:52 AM Re: 2005 Xterra Front Bumper
Jim If I order a bumper from you what is the wait time like until delivery?
#392953 - 08/07/06 12:03 PM Re: 2005 Xterra Front Bumper
Shrock Offline
Loc: Houston, TX
Build time on a 2005+ bumper is about 3-4 weeks right now.
Jim Shrake
www.ShrockWorks.com
#392954 - 11/07/06 07:40 PM Re: 2005 Xterra Front Bumper
srpage,
Thanks, I'll have to try that out. laugh
