#393849 - 01/11/02 10:35 AM SLR 4130 Torsion Bar Anchor and Adjuster
Spencer Low Racing Offline
Loc: Parker
SLR-designed torsion bar anchor and adjuster are crafted from 4130 plate and tubing. A must for use with additional weight (winch, bumper) or preloading bars to obtain lift. A direct OEM replacement part using better material and TIG welded to ensure proper penetration. Heat treated to obtain unmatched strength and durability.
When using a larger diameter torsion bar or preloading your bars to obtain ride height, the OE torsion bar anchor becomes a weak link in your suspension. In SLR's experience with the use of our 300m torsion bars being used under extreme conditions, the OE torsion bar adjuster starts to fatigue and crack at the weld seams. SLR has analyzed and Rockwell tested an OE torsion bar adjuster. The OE adjuster did not register on the C-scale.
OEM torsion bar adjusters were not designed to withstand the abuse of using 4340 or 300m material torsion bars. In my opinion, OEM did not start with the right material.
We have designed these anchors to use up to a 30mm torsion bar (OEM 24.5). These anchors with SLR bars will give you additional torsional twist and a better spring rate. Testing and design is complete (yes conceptual design to delivery in less than 6 months eek . Pricing and availability will be updated on 2slr.com. Product release date estimate mid/late November-early December.
Please call 928-667-4757 or email info@spencerlowracing.com if you have any questions. Thank you for your time and support.
>>>SLR
#393850 - 01/11/02 05:07 PM Re: SLR 4130 Torsion Bar Anchor and Adjuster
XSAL Offline
Loc: 94043 -> 19355
Is this a comparison picture of SLR (top) and OEM (bottom)? Or, two different types of SLR anhcors?
...Just trying not to make any assumption...
#393851 - 01/11/02 06:28 PM Re: SLR 4130 Torsion Bar Anchor and Adjuster
Todrick Offline
Loc: Arizona
looks like the new SLR on top
and
an old used(broken) on bottom
(i see what appears to be a crack in the lower portion of it)
#393852 - 01/11/02 08:39 PM Re: SLR 4130 Torsion Bar Anchor and Adjuster
2001frontier Offline
Loc: Fort Worth, TX
Is it just me or does the top one look shorter? Are the SLR bars the same as the SAW T-Bars. I have those on my truck, and I am wondering if Spencer's are different, and if they are better for some reason?
