#410408 - 07/09/05 07:55 PM what is the best rpm
hey anyone out there...at what rpm do u get the best gas milage ..like pulling away from a red light can u take it up to 2000 or 3000 rpms which is better
#410409 - 07/09/05 08:35 PM Re: what is the best rpm
lower rpm is better on MPG as a general rule.
#410410 - 07/09/05 08:37 PM Re: what is the best rpm
true, but depends if your in a stick or not, also, if you shift too early in a 5spd and you wanna get some speed, mashing on the gas in the wrong gear isnt going to save you any gas either
#410411 - 08/09/05 02:58 AM Re: what is the best rpm
ChuckH Offline
[b]lower rpm is better on MPG as a general rule.
true, but depends if your in a stick or not, also, if you shift too early in a 5spd and you wanna get some speed, mashing on the gas in the wrong gear isnt going to save you any gas either[/b]
Exactly. I find that my mileage improves dramatically if I use more revs and less throttle when climbing hills. Best thing to do is not worry so much about the revs, but pretend there's an egg between your foot and the gas pedal so you don't mash it down.
