Originally posted by alamocoastie:
RI X - there needs to be some sort of connection to balance out the pulses from each side. It has been proven that h-pipes are better that straight, and it seems that x-pipes are better than h.
Badfnz - I had never heard of using a dual in muffler to balance things out. But if it looks like there would be room for an x-pipe, that's the way I will go.
Slanty - thats another major concern. Gas tank location. Is it inside or outside the frame rails?
I'm sure there is room for an x-pipe. I was just saying if you wanted to save money and cut probably 20-30lbs out of the whole system, you could use 1 muffler as a crossover.
If you want to run an x-pipe, Dr. Gas makes junctions in different diameters. I'd use that as the crossover and fab up the exhaust to that. X-pipes generally make a little more power but usually sound more raspy when compared to the h-pipe.
