139
#411771 - 30/03/06 08:18 PM
+20HP power speed chip???
Hi All, What do you guys think about this? http://cgi.ebay.com/ebaymotors/20HP-POWE...1QQcmdZViewItem Using a resistor to override the sensor to increase up to 20HP. According to the seller "This is a resistor with directions that will show you how to modify your AIR/Fuel ratio and slightly change your engine timing to run stronger and with increased power." Thanks Stephen
#411772 - 30/03/06 08:24 PM
Re: +20HP power speed chip???
Woaaaa - Add one of those crazy Tornado things and your set. 40 / 50hp gain!!!!
Sorry dude, but that chip don't do shit. Welcome to XOC.
#411773 - 30/03/06 08:35 PM
Originally posted by RiNkY: Woaaaa - Add one of those crazy Tornado things and your set. 40 / 50hp gain!!!!
Sorry dude, but that chip don't do shit. Welcome to XOC. search about similar chip mods in the performance forum and you'll know all you ever needed to know about resistors altering timing oh, yeah, welcome to XOC!
#411774 - 30/03/06 08:37 PM
Thanks for your comments. That's kind of what I thought also. Hopefully, nobody Xterra owners would do this to such a great vechile.
#411775 - 30/03/06 08:55 PM
Thanks guys. XOC is really new to me. But I check out the XOC everyday since I brought my X, just like checking my email.
#411776 - 30/03/06 09:04 PM
Ditto the above..and welcome!!
#411777 - 31/03/06 12:12 PM
I heard those things just advance timing. Very bad thing to play around with.
#411778 - 31/03/06 03:26 PM
Loc: 100 Mile House, BC
Nah, those don't work too well. I'll tell you what does though: the hair blower electric supercharger! Holy shit, you should've seen me blow by that Enzo! Ok, in all seriousness, if something sounds too good to be true, it probably is.
#411779 - 01/04/06 06:28 AM
timing is not a bad thing to play with. this may not be the way to go about it, but adjusting timing just gets you optimal performance. just like everything else, too much can be detrimental, just like leaning your afr. but to say it is a bad thing to do is way to general.
#411780 - 01/05/06 02:01 PM
Hey all... so it the consensus that even the tornado chip is bull or is there a chip modification that increases hp? I'm installing a KN-77 cool air intake and a Gibson cat back system on my 05 off road next week and would love to get the HP over 300! Any not so painful ways from here... thanks!
#411781 - 01/05/06 02:07 PM
Please ignore the "tornado chip" comment above I'm really not that stupid but I would still like to know how I can squeeze an extra 15-20 hp out of my OR after installing the exhaust and air filter... thanks
#411782 - 01/05/06 05:00 PM
Snake oil, the trap of all newbs....It rocks......
#411783 - 02/05/06 12:06 PM
There is no "chip" mod that works on an Xterra, period. You can send your entire ECU off to www.jetchip.com and get it re-programmed for $300, but that's a completely different concept. Good luck getting an Xterra to 300 hp without extensive modification.
#411784 - 03/05/06 04:56 AM
Well just doing the math... stock 05 xterra at 265hp add KN cool air and Gibson cat back each worth up to 15 hp extra that's 295hp... what about a throttle body spacer or retuning timing with one of the various units for sale out there? Seems like getting another 5hp isn't out of the relm of possibility... I realize that your X only cranks out 190hp and 300 seems pretty far off from there but there must be some less than extreme modifications out there
#411785 - 03/05/06 09:41 AM
Throttle body spacers are junk.
#411786 - 19/05/06 03:24 PM
Anybody know if the famous Nissan man Steve Millen is doing anything lately?
#411787 - 19/05/06 03:39 PM
Loc: Arizona
#411788 - 19/05/06 03:52 PM
Originally posted by OffroadX: Throttle body spacers are junk. so are those spacers really garbage?? i talked to someone that had it and they liked it. but then again that was only one guy.
#411789 - 19/05/06 04:24 PM
They can't possibly work, the fuel is injected so far downstream that any effect it might have on the airflow is negated by that point.
#411790 - 19/05/06 11:07 PM
from the research that i've done, on the nissan Z the spacer makes a very large improvement. why wouldn't make an improvement on the X.
im not trying to prove anyone wrong or right. i just want to know if it actually works on either model.
#411791 - 20/05/06 07:12 AM
So go against our advice and blow $90 on one and prove us wrong...
#411792 - 21/05/06 12:29 AM
Try looking into Cobb tuning . As we speak they are working on a chip or reprograming of the '05 X ECU. I know this for a fact, I donated my ECU for them to break the coding on. They will start some dyno testing the first on June. I can't pedict their marketing date, but be patient. These guys are some of the best in the industry. Check them out Cobbtuning.com I posted on the header topic also. Nismo has the '05 headers out. They also have a air intake w/filter. I personally plan to do all three of these to my Xterra racer.
