#414177 - 15/09/03 05:01 PM K&N FIPK Kit
vwroom Offline
Loc: Seatttle, WA
I got a question for those with a K&N FIPK or Air Charger Kit. Is the air temp sensor that sits in the filter actually part of the filter or is it another piece in the kit? I am asking because my room mate has convinced me to fab my own intake and just buy the filter but, I am concerned about locating the air temp sensor.
Thanks,
Bryan
#414178 - 15/09/03 05:58 PM Re: K&N FIPK Kit
bpdA Offline
Loc: Chicago IL, Orange Co. CA, and...
The sensor is actually mounted directly to the filter via a pre-drilled hole.
www.brettpatrickdougherty.com
#414179 - 15/09/03 06:17 PM Re: K&N FIPK Kit
perna Offline
The sensor pops out easy, if you buy the FIPK it mounts into the heat shield. If you make you own intake you can put it whereever you want.
#414180 - 16/09/03 05:35 PM Re: K&N FIPK Kit
Kerensky97 Offline
Loc: Utah
confused
The air sensor on mine goes in the back of the cone filter. I got the Aircharger before it became a FIPK but I don't think they changed it (and they shouldn't, the sensor should be in the path of incomming air).
-Dustin
Xterra101.com
#414181 - 16/09/03 05:49 PM Re: K&N FIPK Kit
rrdstarr Offline
Loc: Tacoma
[b]The sensor pops out easy, if you buy the FIPK it mounts into the heat shield.
confused
The air sensor on mine goes in the back of the cone filter. I got the Aircharger before it became a FIPK but I don't think they changed it (and they shouldn't, the sensor should be in the path of incomming air).[/b]
That's right it goes into the rubbr housing where the filter attaches.
-Rick
#414182 - 16/09/03 07:32 PM Re: K&N FIPK Kit
Whats the best price online for this kit? whats the part number too? Thanks
#414183 - 27/09/03 11:24 AM Re: K&N FIPK Kit
rrdstarr Offline
Loc: Tacoma
This is where I bought mine from and several of our club members did too. $224.25
http://www.4filters.com/find.asp
-Rick
#414184 - 27/09/03 01:55 PM Re: K&N FIPK Kit
bpdA Offline
I got mine from Crutchfield for $229 incl shipping and it was here in 2 days. I like their return policy the most so I figured that if I didn't end up liking the piece, I could send it back for free...no loss.
#414185 - 03/10/03 07:49 PM Re: K&N FIPK Kit
perna Offline
Im sorry on non SCs the air temp sensor does go in the filter. On SCs it goes in the heat shield.
#414186 - 17/10/03 07:48 PM Re: K&N FIPK Kit
racinj Offline
Loc: NW Oregon
Talked to dealer mechanic about putting on K&N and suggested not to do it because the air sensor gets oil from the filter on it and it ruins the sensor and cost BUCKS to replace.
Is this a valid point? Are there ways to avoid this problem? I have a 02 S/C.
#414187 - 17/10/03 08:50 PM Re: K&N FIPK Kit
Just don't over-oil it, and make sure you let it dry correctly after cleaning.
The air temp sensor is really out of the way, it's the mass air sensor that can get damaged and is expensive.
#414188 - 17/10/03 11:07 PM Re: K&N FIPK Kit
ChuckH Offline
Like XOC said, just make sure you clean and oil it correctly. I've been running my K&N AirCharger for about 40,000 miles and ran a K&N panel filter for 30,000 miles before that and my MAF still works. smile
#414189 - 18/10/03 03:41 PM Re: K&N FIPK Kit
I've been running mine for about 6000 miles and have not noticed any problems. It is a little louder then I thought it would be, but I can put up with it with the gain in power I feel.
#414190 - 20/10/03 02:06 PM Re: K&N FIPK Kit
X - FACTOR Offline
Loc: OH
I have been using my POP charger for about the past 10,000 miles and I did not reinstall the air temp sensor back.
I am not sure how this is affecting performance but I have not seen any drop.
"LIFT HARD...RIDE HARD"
#414191 - 02/11/03 03:25 PM Re: K&N FIPK Kit
vwroom Offline
Loc: Seatttle, WA
you can get a MAF sensor adaptor from SLR www.2slr.com and then buy filter RX-4750 and then you have an intake for a little over a hundred bucks.
Bryan
#414192 - 02/11/03 07:13 PM Re: K&N FIPK Kit
PoorBoy Offline
Loc: Nacogdoches, TX
May be kind of a dumb question. I've been wanting to get one, but been a little concerned about getting mud and water on the filter. I went through some stuff today(not mudding, just muddy water) and looked under the hood and it was getting pretty dirty already. How much does it affect it? Will I just have to take it off and clean it pretty often?
Jonathan
