#418367 - 10/07/06 08:14 PM Calmini front leveling option
what exactly does this accomplish besides levveling the front to the heighth of the rear. Any thoughts or comments. Thanks.
#418368 - 10/07/06 08:17 PM Re: Calmini front leveling option
Calmini front leveling option? Where you see this?
The front is lower than the rear on purpose, so I dunno what you're talking about.
#418369 - 10/07/06 08:25 PM Re: Calmini front leveling option
http://www.purenissan.com/coil_spacer_kit.htm
this is what I meant to post, i just couldn't think of the description....sorry! Thought someone would be able to help.
#418370 - 10/07/06 08:34 PM Re: Calmini front leveling option
This is generally used in conjunction with the shackles in the rear to give 2.5" of lift overall.
#418371 - 10/07/06 08:44 PM Re: Calmini front leveling option
would it be something worth purchasing?
#418372 - 10/07/06 08:57 PM Re: Calmini front leveling option
Do you need a lift? Do you want a lift?
Planning to use a lift off-road? Maybe you need a little more clearance for the terrain you traverse? Do you offroad at all?
Basically what I'm saying... you don't need it unless you want your truck to look taller or you want it for practical reasons like a little more clearance on the trail.
#418373 - 10/07/06 09:01 PM Re: Calmini front leveling option
What he said laugh
#418374 - 11/07/06 05:07 AM Re: Calmini front leveling option
Essentially, it levels the front AFTER YOU HAVE LIFTED THE REAR.
So - Is it something you should consider?
Did you, um, lift the rear?
Do you want to?
You'd also need to purchase the parts that lift the rear...
You would be installing a lift kit, raising the truck about 2.5".
Its a small lift, and would not make a big difference in handling or ride, so its pretty much a ground clearance improvement.
If your ground clearance is a problem, and another 2.5" would be worth it, sure, its a good idea.
They also have a 5" lift kit if 2.5" is too little for your clearance problem...albeit 5" is more of a significant center of gravity change....and being released along the lines of New Windows Updates an other similar schedules...
So - does this work for you?
No wrong answer, only you know what you need.
#418375 - 11/07/06 11:54 AM Re: Calmini front leveling option
Thanks TJ....very well thougt out!
