#420436 - 27/05/07 06:55 PM Calmini 5" **FINISHED**
Finally finished!!!!!!!!
The front tires are rubbing very badly.... Im going to have to get a BFH and bash it in, or take it to a body shop and have it done right... I can also crank the coilovers up some more... we will see!
#420437 - 29/05/07 01:46 PM Re: Calmini 5" **FINISHED**
#420438 - 29/05/07 09:48 PM Re: Calmini 5" **FINISHED**
Nice! [ThumbsUp]
I think I would have used lime green on the shackles
(just to be even more different)
#420439 - 30/05/07 10:24 AM Re: Calmini 5" **FINISHED**
Just curious, I looked around and could not find the reason why to use the Radflo coil overs and Total Chaos A-arm in conjunction with the Calimini 5". More travel? More lift? More clearence under the diff? Stronger front end?
#420440 - 30/05/07 11:43 AM Re: Calmini 5" **FINISHED**
More travel.... yes
More lift..... yes
More clearance.. slightly
Stronger front end.... definitely
I am combining two things basically....
alot of people are using the Radflo's and TC uca's as a small lift set up for their trucks (from 0 to 3") which gives you lift and more travel (replaces factory stuff). Well the Calmini lift retains all that factory stuff. So I just decided to replace it. So instead of 5" lift with all the factory characteristcs. I have a 5" lift that can be adjusted up to 7" of lift with all of the bad ass characteristics that come with the Radflo/TC setup. Oh and the coilovers are different than the ones he sells on his site. I believe that these might be for a titan lift or something but they are adjustable and can give you from anywhere between 4 and 7" of lift.
Does that answer you question?
#420441 - 30/05/07 05:44 PM Re: Calmini 5" **FINISHED**
May I ask, many inches of clearence do you have under the front diff? Right now I have only 8". How about top of tire to bottom of wheel well? I would like to compare...
#420442 - 30/05/07 10:25 PM Re: Calmini 5" **FINISHED**
I will check on that tomorrow morning!
#420443 - 30/05/07 10:54 PM Re: Calmini 5" **FINISHED**
Nice, looks good. I see I'm not the only one doing suspension work after GONE.
#420444 - 31/05/07 06:41 AM Re: Calmini 5" **FINISHED**
Well the pictures have me on wheel travel. That looks priety darn good for IFS [ThumbsUp]
#420445 - 31/05/07 06:55 AM Re: Calmini 5" **FINISHED**
Looking good.. [ThumbsUp]
#420446 - 31/05/07 12:00 PM Re: Calmini 5" **FINISHED**
That looks great, wasn't too sure about the bright orange shackles with the Calmini blue, but that was before I saw it all together.
Awesome flex for IFS.
