#420549 - 11/06/02 11:20 AM How high can I raise my XE utilizing stock bolts?
SFYellowXE Offline
Loc: San Francisco
Well, as I posted in my previous post I know that hight in sport cars like Corvette for example can be adjusted within 1" - 2" on a stock leaf spring bolts.
Can I achieve same thing with my XE? I plan to put higher tires (from 265/70/15 to 31/10.5/15), therefore gaining an inch of ground clearance from the tires and if I can squiz 1.5 - 2" increase from the stock bolts, then total of 2.5" increase in ground clearance is all I desire.
If not can you post the least expensive way to increas my ground clearance (to go over rocks) between 2" - 3"?
Thanks!
#420550 - 11/06/02 11:24 AM Re: How high can I raise my XE utilizing stock bolts?
The Xterra is not a Corvette. It would be wise to leave it alone instead of putting bolts all over it.
#420551 - 11/06/02 11:45 AM Re: How high can I raise my XE utilizing stock bolts?
ILUVMYX Offline
Loc: San Diego, CA
Since when do Vettes have leaf springs?
http://www.feedforspeed.com
#420552 - 11/06/02 11:56 AM Re: How high can I raise my XE utilizing stock bolts?
SFYellowXE Offline
Loc: San Francisco
Since 97, C5 have a leaf spring.
#420553 - 11/06/02 12:24 PM Re: How high can I raise my XE utilizing stock bolts?
ILUVMYX Offline
Loc: San Diego, CA
While technically it is a leaf spring it couldn't be more different than what the Xterra has. The Vette has independant suspension with a single leaf spring (made out of fiberglass) mounted transverse and does its duty for both sides in a completely different way than traditional leaf springs. Have you ever looked at your Xterra's springs? Here is a picture of the Vette:
#420554 - 11/06/02 01:13 PM Re: How high can I raise my XE utilizing stock bolts?
GrayHam Offline
eek
Bookcase, carpeting . . .
I thought I was a little different for keeping my bike in the dining nook . . .
Someone's keeping a Corvette in the freaking den!
#420555 - 11/06/02 07:35 PM Re: How high can I raise my XE utilizing stock bolts?
Dayspring Offline
Loc: Greenwood IN
Do a search for Add-A-Leaf. You'll find a host of information on raising the ass-end.
Thanks!
