If anybody cares, here are the ACTUAL US fine threaded bolts I used on my Xterra body lift instead of Metric bolts
US threaded bolts for the Xterra
From the front:
2 - 7/16" x 6" bolts, nyloc nuts, washers
2 - 3/8" x 6" bolts fine thread(24tpi), washers
2 - 7/16" x 6" bolts fine thread(20tpi), washers
All bolts need to be Grade 8
Use thread loc on all threads
It is entirely up to you if you use US or Metric threads on the body bolts. Make your own decision. This is just an alternative suggestion. Like already said, about .2% difference in thread pitch between the two.
Good source body blocks:
www.sportztrailers.com 10 - 3" dia body blocks
