#421602 - 16/12/07 03:27 PM Xterra rattles over bumps
2001 Xterra rattles over bumps. Sounds like front passenger side.
checked under to see if any bushings are gone or torn up and everything looks tight and present.
I have no idea what it may be.
It rattles in the same place if I suddenly turn the vehicle right or left.
I am perplexed.
Any help before I take it in and get fleeced for a job I can do for 50 bucks????
#421603 - 17/12/07 10:53 PM Re: Xterra rattles over bumps
Could be a heat shield.
#421604 - 12/01/08 04:06 PM Re: Xterra rattles over bumps
I have same sort of rattle. Seems to only happen in morning when X is cold. It is driving me crazy trying to figure it out!
2002 X
#421605 - 13/01/08 06:11 PM Re: Xterra rattles over bumps
GrnXnham Offline
Loc: Tacoma, WA
Same rattle here. More common when it's cold out or when I'm 1st driving it and the truck is cold. Somewhere under the front passenger side. I'm not sure where to look 1st.
2002 Xterra XE 190K
2012 Frontier S 64K
2007 Toyota Tundra 103K
#421606 - 14/01/08 05:40 AM Re: Xterra rattles over bumps
is this more of a squeak than a rattle? because ive had a squeak for about a year now mostly when its cold, ive had it looked at numerous times and cant find a thing
#421607 - 15/01/08 10:40 AM Re: Xterra rattles over bumps
Joe-Nathan Offline
Loc: St. Martinville, LA
I have the same type of rattle. But mine is due to the fact that the front skid(factory) is loose. My mech/sevice shop did not tell me that I only have two screws holding it in place. So you might want to check this also, especially if you have an older truck.
2000 SE 4x4 (good bye)
Super Black
2007 Quest SL
2011 Titan CC Pro-4x (Smoke)
"The difference between death and taxes is death doesn't get worse every time Congress meets." -- Will Rogers (1879-1935)
#421608 - 16/01/08 05:52 AM Re: Xterra rattles over bumps
I have had numersour sqeaks on my X and my old frontier. I finally attributed them to the stuff they put down for snow (salt) or if I go 4-wheelin and get alot of mud in the under cariage. My remedy for this is to do a complete under carriage wash at the local car wash and then spray all my bushings and joints under the X with a 3M silicone spray. This works for me.
#421609 - 16/01/08 08:22 AM Re: Xterra rattles over bumps
Same thing with mine when its cold. Heat shields!
