#423111 - 28/11/01 12:44 PM Torsion Bar - suggestion
Cougar Offline
Loc: Germantown, MD, USA
Hey guys, is it NECESSARY to update my torsion bars if i plan to have a winch(warn 9500i)? I meant i know it's better to upgrade but is it really necessary? what brand of torsion bars do you recommand? confused
#423112 - 28/11/01 12:56 PM Re: Torsion Bar - suggestion
Carlton McMillan Offline
Loc: MN
Necessary? Depends on who you ask and how often you want to replace your Torsion Bars.
Without going to a larger bar you will wear out the O.E. bars at a rather fast rate.
As far as which bars to get..
I can only speak from what I have. I have the Nissan Motorsport/Sway-a-way bars. Got them from Xterraparts.com and have been very happy with them.
#423113 - 28/11/01 02:36 PM Re: Torsion Bar - suggestion
Cougar Offline
I can only speak from what I have. I have the Nissan Motorsport/Sway-a-way bars. Got them from Xterraparts.com and have been very happy with them.[/QB]
I don't have a winch bar. I am not gonna have my winch mount fixed.
did you put on torsion bar yourslef? was it hard?
#423114 - 28/11/01 02:51 PM Re: Torsion Bar - suggestion
Loc: MN
How are you planning on using a WARN9500I without a winch bumper?
I did not install them myself. I had Nissan do it. :-)
#423115 - 28/11/01 04:39 PM Re: Torsion Bar - suggestion
Cougar Offline
yeah it's probably better to have a nissan tech to do the job. how much did they charge you? i hope it's not going to cost me a fortune
#423116 - 28/11/01 05:21 PM Re: Torsion Bar - suggestion
Strom Offline
Loc: Los Angeles, CA
Wouldn't this go in Suspension?
#423117 - 28/11/01 05:25 PM Re: Torsion Bar - suggestion
Cougar Offline
they sell portable winch carrier. it hooks up to your tow hitch. I am getting a front receiver/hitch and a portable winch carrier. i am trying not to get a bull bar b/c i want my winch to be portable (front or rear). if i do decide to change my vehicle a few years down the road, i would like to move my winch to new suv/truck.
my only concern is that when i have my winch put on, would it do any kind of damage on the torsion bar or suspension part?!?
#423118 - 28/11/01 06:14 PM Re: Torsion Bar - suggestion
Kerensky97 Offline
Loc: Utah
Make sure the front hitch is connected to the frame very well.
I've seen people get those movable winches and put a Class II reciever in front.
Class II is rated for 3500 lbs and the winch is rated for 9000 lbs, do the math.
After one pull the reciever brace had distorted and one mounting bolt had its head sheared off.
-Dustin
Xterra101.com
#423119 - 29/10/02 02:31 PM Re: Torsion Bar - suggestion
Xtasy Offline
Loc: Phoenix, AZ
Does anybody recommend that you do the Torsion Bar upgrade yourself or should this be professional done? If so, are there instructions posted that anybody is aware of?
Life is the Journey, not the Destination
#423120 - 29/10/02 05:12 PM Re: Torsion Bar - suggestion
rrdstarr Offline
Loc: Tacoma
I have done four torsion bar upgrades. Fairly easy to do if your mechanical competent. Here is the link to follow for do-it-yourselfers.
http://www.automotiveforums.com/vbulletin/t3937.html
-Rick
#423121 - 29/10/02 08:46 PM Re: Torsion Bar - suggestion
JerseyX Offline
Loc: Manchester Twp. NJ
Here, you can also use this. I got this from the Automotive Customizers site. Reindexing Torsion Bars Hope it helps. Good luck.
"LIFE...sexually transmitted and always fatal."
#423122 - 15/02/04 07:24 AM Re: Torsion Bar - suggestion
That PDF from Automotive Customizers is crap and doesn't explain anything about how to replace torsion bars correctly.
Replacing the stock torsion bars is pointless unless yours are sagging severely. Your removable winch mount will be in the back of the vehicle, and not mounted unless you need it.
#423123 - 15/02/04 10:51 AM Re: Torsion Bar - suggestion
eric k. Offline
Loc: northern virginia
I spoke to my local dealership,they said would install the bars for me,it would be about 2hrs[$62.00 phr],Also can any body tell me the diffrence in the calmini and the ones on xetrra.com?[other than price],and which ones are the better choice? thanks
#423124 - 15/02/04 10:56 AM Re: Torsion Bar - suggestion
Cougar Offline
I did myself with no prior expreience. it's not hard at all. i think calmini and xterra.com are the same but the color
