#423532 - 26/07/04 10:07 PM Cracking niose
got a question...
When I make a sharp turn on my 03, 2wd, I hear a cracking noise coming from the front wheels.
I have not gone offroading but have traveled a bit.
called dealer and they said it was "normal".
what do you guys think?
#423533 - 27/07/04 06:53 AM Re: Cracking niose
xterra3202 Offline
Loc: Georgia
im on mechanic but "normal" sounds to me like they are too lazy to look at it. take it in and see what they say. i can almost guarantee you that they will say it's normal so try and get a second opinion. if it is still doing it call Nissan and bitch to them. that really doesn't work either but maybe you will have better luck than what i have had!!!
Tim
Thomas Jefferson
#423534 - 27/07/04 07:19 AM Re: Cracking niose
I can't see how a cracking noise when you turn could be normal...unless there are shopping carts or glass carriers, etc... on either side of you. wink
There are other things that can make a cracking noise on a sharp turn...and all are bad.
I'd make them look at it, take it apart, and see if the brakes or CV's or ball joints, etc are OK.
smile
#423535 - 27/07/04 07:58 AM Re: Cracking niose
I always thought that noise could be considered normal, that grinding, rusty noise when you bump something while turning with your wheels completely turned. Isnt ?
#423536 - 27/07/04 01:26 PM Re: Cracking niose
Geez, am I going to be the first to say "steering stops" here? More info to be found by searching that phrase in problems/annoyances...
#423537 - 27/07/04 04:10 PM Re: Cracking niose
Haven't had much experience with my X yet, but the steering stops on my 4Runner would make the most tortuous, unholy sounds imagineable at full turn - not so much a crack, but sometimes a loud knock.
#423538 - 27/07/04 10:38 PM Re: Cracking niose
[LOL]
Check this out. I took it to the dealer today and they said they would look at it.
Im ok with that.
My boss told me it just needed a little lubing. I didnt believe him, well It turns out that a little lubrication did the trick.
..................There is a recall on the fuel line system. It has to do with possible corrosion......................
thanks
