#423936 - 04/04/04 01:32 PM Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
I had the torsion bars raised in the front end to accommodate new Interco SSR tires and now the front end is slightly higher than the rear.
I was looking at a stage II SLR suspension lift, but after they took my money on a previous order and sent me their product 11 weeks later, I refuse to go with SLR and their poor service.
I was thinking that I'd just get shackles giving a one or two inch lift to replace the OE ones and then put in the 5100 Bilstein shocks for a smoother ride and to raise the rear, so that it is higher than the front. I'm sick of seeing it look like a 4runner with that rear end sag.
Anyone, have any better ideas for increasing the rear without a costly suspension lift? My solution is two new shackles (where is the best place to get them for the X?...and not SLR) + 5100 Bilsteins. I sent an e-mail to Old Man EMU,no reply, but they only advertise Aussie Nissan variants.
Recommended Shackles for at least a one inch rear lift...anyone? I read that a differential lowering Kit would not be needed, so a confirmation by a second party would be good. Thanks
#423937 - 04/04/04 01:48 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
Why not just go for the Calmini Add-a-Leaf?
It won't sag as quickly.
http://www.purenissan.com/suspension.htm
They also sell shackles.
#423938 - 04/04/04 02:27 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
You don't need a diff lowering kit for just a torsion twist. Calmini shackles are 1.5" - I have a set on my Xterra. You can order them from www.xterraparts.com. I've had good luck with them and I've never heard anybody complain about them - which is saying quite a bit because the do a lot of business w/ members of this board.
#423939 - 04/04/04 03:33 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
Go with the shackles, Calmini very high quality and like pnw said no one ever complains about them. And Xterraparts.com is awesome with customer service!! I wonder how much stuff you have to buy to get a discount card? [Smoking]
#423940 - 04/04/04 03:35 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
TrialsX Offline
Loc: Florida
I have the full 3" suspension lift from Calmini, and I've never heard my CVs pop. I don't plan on lowering the front diff unless the CVs were binding.
Two ways to consider for raising the rear on the X. AALs (add a leafs) or the calmini shakles as mentioned. Both will add about the same amount of lift, 1.5" each.
Shackles would be slightly easier to install. I have also not heard anything good about SLR, both on the service side and the quality side. My Calmini hardware has been great for the last 2 years.
www.mikemelchior.com
#423941 - 04/04/04 05:28 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
hey-
i was considering the same thing you were... i raising the front and wanted to balance it out...
calmini is definetly the way to go! they make great products. as far as which one between shackles and AAL's. i went with the leafs because in the long run i think they are more beneficial. they raise the payload and in my opinion make the X handle better on bumps and crap. its only 100 more for something that is going to last the lifetime of the X, i really didnt think saving 100 was going to be worth the possible problems with sagging and such.. plus i thought the ride was too soft anyway.
either way its a good choice and calmini is a great company with quality products and good customer service.
#423942 - 05/04/04 03:44 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
Well, I just returned from work and to my surprise, I found lots of great advise from all of you, so thank you. I will be contacting xterraparts.com for Calmini products ASAP (Bye SLR for EVER!). I am fairly new to this site, so the benfits of the superb advise has convinced me it wasn't a waste of time. I tip my hat to you gentlemen....hard to know if you are all men since I didn't check the properties of everyone, so anyway, Much appreciated.
#423943 - 05/04/04 04:13 PM Re: Elevating the Rear End (Cheapest Way?): Old Man Emu Shackles perhaps?
TrialsX Offline
Loc: Florida
I'm not afraid to show my feminine side.... [Spit]
